Buying wrenches - SAE or Metric or both?
Old 10-19-2017, 01:11 PM
Mayor111
CF Senior Member
Mayor111's Avatar
Default Buying wrenches - SAE or Metric or both?
Hey Guys,
Going to be buying a set of wrenches - which are need for a C5 - SAE or metric?
Also - can you tell me which sizes are most common for a Vette?
Thanks!
Mayor111 is offline
Old 10-19-2017, 01:42 PM
dannyzabolotny
CF Member
Both. It's kind of a random mix of SAE and metric, just like most other American cars of this era. My 96 Mustang was a totally random mix too.
dannyzabolotny is offline
The Following User Says Thank You to dannyzabolotny For This Useful Post:
Mayor111 (10-19-2017)
Old 10-19-2017, 01:46 PM
grantv
CF Senior Member
grantv's Avatar
Mostly metric, 11, 13 I think are pretty common, but just buy a set.
grantv is offline
The Following User Says Thank You to grantv For This Useful Post:
Old 10-19-2017, 01:57 PM
IMXCITD
CF Senior Member
Support Corvetteforum!
IMXCITD's Avatar
I'd get an entire set of both.....there are countless uses for them and it's good to be prepared to handle a project.
IMXCITD is offline
The Following User Says Thank You to IMXCITD For This Useful Post:
Old 10-19-2017, 02:01 PM
c4cruiser
CF Senior Member
c4cruiser's Avatar
I would get a set of metric wrenches in a range from 8mm to at least 19mm. Most sets will be in 10mm to 19mm range so smaller and larger wrenches like 8 and 9mm and 20 and 21 mm will have to be purchased separately. Note that there are some metric sizes that are almost the same as SAE sizes.
Certainly won't hurt to get a set of SAE wrenches too. Most sets will have 1/4" thru 3/4" sizes.
I would also recommend getting ratcheting/swivel wrenches These will help removing nuts and bolts without having to have sockets and ratchets.
c4cruiser is offline
The Following User Says Thank You to c4cruiser For This Useful Post:
Old 10-19-2017, 02:22 PM
CactusCat
CF Senior Member
CactusCat's Avatar
As stated, its best to have both. Seems like most on the C5 are metric. Smallest ones I remember are the 7mm on the cover under the headlights (on each side) and the biggest was 32 or 33mm on the rear axle nuts. Most fall in between those sizes with 10mm to 19mm covering the vast majority. A good tool set is something that will last a lifetime so get what you need. It's best to have on hand when you need it. I will say the rear axle nuts was special order item for me.
CactusCat is offline
The Following User Says Thank You to CactusCat For This Useful Post:
Old 10-19-2017, 02:40 PM
runner140*
CF Senior Member
runner140*'s Avatar
If you wrench a lot, both.
runner140* is offline
The Following User Says Thank You to runner140* For This Useful Post:
Old 10-19-2017, 02:44 PM
Moderator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
The C5 uses mostly metric, but you would be surprised how many uses you will have for a set of SAE sockets/wrenches.
Vetteman Jack is offline
The Following User Says Thank You to Vetteman Jack For This Useful Post:
Old 10-19-2017, 03:38 PM
pewter99
Admin
pewter99's Avatar
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
both but get an extra dozen 10mm sockets
pewter99 is offline
The Following User Says Thank You to pewter99 For This Useful Post:
Old 10-19-2017, 03:52 PM
MBVette
CF Senior Member
MBVette's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10
no ****. regular and deep well, they disappear like the second sock in a pair.
MBVette is offline
The Following User Says Thank You to MBVette For This Useful Post:
Old 10-19-2017, 03:54 PM
dannyzabolotny
CF Member
Ah yes, the elusive 10mm and 13mm sockets... you can never have enough of them. They always go missing!
Old 10-19-2017, 04:24 PM
ztheusa
CF Senior Member
ztheusa's Avatar
And an assortment of "torx" screw driver tips.
ztheusa is offline
The Following User Says Thank You to ztheusa For This Useful Post:
Old 10-19-2017, 04:57 PM
Phanni
CF Senior Member
Phanni's Avatar
Virtually everything is metric on C-5 from 7MM to 21MM (engine cradle).
7,10,13 15 are most used.
Phanni is offline
The Following User Says Thank You to Phanni For This Useful Post:
Old 10-19-2017, 05:00 PM
skydiven4fun
CF Senior Member
skydiven4fun's Avatar
St. Jude Donor '13-'14-'15
Good advice
skydiven4fun is offline
Old 10-19-2017, 05:04 PM
skydiven4fun
CF Senior Member
Get this and be done with it
The Following User Says Thank You to skydiven4fun For This Useful Post:
Old 10-19-2017, 05:30 PM
dannyzabolotny
CF Member
Interesting, my 96 Mustang is still a mix of both. I wonder what made GM go almost full metric with the Corvette. Probably for ease of assembly as more and more components became metric?
Old 10-19-2017, 08:37 PM
6speedsteve
CF Senior Member
6speedsteve's Avatar
And metric allen wrenches if you are doing any suspension work.
6speedsteve is offline
The Following User Says Thank You to 6speedsteve For This Useful Post:
Old 10-19-2017, 08:39 PM
juanvaldez
CF Senior Member
13 = 1/2 14 = 9/16 19 = 3/4
juanvaldez is offline
The Following User Says Thank You to juanvaldez For This Useful Post:
Old 10-19-2017, 10:11 PM
fuggles
CF Senior Member
fuggles's Avatar
Not exactly.
fuggles is offline
Old 10-19-2017, 10:12 PM
juanvaldez
CF Senior Member
Originally Posted by fuggles View Post
Not exactly.
Close enough!
Quick Reply: Buying wrenches - SAE or Metric or both?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
