wicked disappointed
wicked disappointed
hey all,
Much to my extreme chagrin, after only a handful of times driving my 03 Z06, where it seemed to shift fine, it has become evident that the transmission will need a rebuild. This prognosis was preliminarily from my new amigo corvetteforum.com member Josh, and then subsequently Buyavette. It grinds into second and reverse pops out. 4th is a bit sketchy as well. I got an estimate of $2700, which will take me a few months to scrounge. That all being said, my question is- is it better to limp it around once a week to try to keep everything circulating or no? What is the best way to preserve the tires/batter/fuel stability when its going to sit for 2-3 months?
Pro Mechanic
Bummer about the trans
Letting it sit for several months won't hurt anything, just put a tender on the battery so it doesn't die...
Sorry to hear about the tranny.
For storage, I recommend the following
1) Full tank of gas (minimum) add fuel stabilizer (recommended)
2) Battery on a tender
3) Change oil (my preference)
4) Park on carpet squares (my preference)
5) Chock wheels and put tranny in neutral and parking brake off ( my preference).
6) Clean interior and exterior so when you're ready to drive the car again it looks ready too.
7) Place fabric softener dryer sheets in the interior and around battery / fuse box if worried about mice.
8) Maybe a container of Damp Rid inside the cabin if it will be humid.
9) Leave the car off until ready to drive again
10) Put note on dash reminding yourself there is a battery tender attached and wheels are chocked.
The following 2 users liked this post by 3sACROWD:
iAmGeranimo (11-09-2017),
kawtipin (11-06-2017)
I take my battery out and store it in the basement on a tender. A battery can go bad at any time and a dead battery will freeze, possibly cracking the case.
I also use moth ***** in the cabin and engine compartment. Stinks for a day or two in the spring, but mice damage can get expensive.
And I shove some stainless steel pot scrubbers up the tail pipes to keep vermin out.
Received 19,293 Likes
'20-'21-'22-'23-'24
Also, if you have a cover for the car, go ahead and place it on the car to keep the dust off the surface.
hey all,
https://www.corvetteforum.com/forums...ems-fixed.html
I rebuilt mine in my 03 20Kmiles ago. If you wrench yourself, you could save yourself a lot of money.
I bought this kit:
http://www.hawksmotorsports.com/t56-...d-kit-package/
and did the work myself. You will need a press to press the bearings on and off. Other than that removal was the most time consuming. Other than that, it wasn't hard. Go ahead and replace the clutch while you're in there.
I bought this kit:
hey all,
My shifter was slipping out of 1st, and grinding going into 4th. Take it for whats it's worth, but after I adjusted my shifter, and installed a new transmission mount all my grinding issue when away. It really made a night and day difference. Might be worth a shot?
What about purchasing a complete replacement and then maybe a kit to rebuild your own.
1999 -2004 Corvette T56 transmission,
https://www.kijiji.ca/v-transmission...nt=app_android
Price: $ 1,500
Something like this would allow you to continue driving your car, then while the transmission is out, you could take your time rebuilding it. Once complete, install it and sell the "temp" tranny for about the same as what you paid.
Price: $ 1,500
Banned Scam/Spammer
Received 1,319 Likes
I just finished my own rebuild on my Z, so when I heard the symptoms I knew right away it needed a rebuild.
To answer you question, you can still drive the car sparingly but know that each time the gear grinds as the collar is slipping into position (the syncro not doing its job) you're putting major wear at the engagement point between the gear and the collar/slider.
I had to replace my 2nd gear and collar and those parts alone cost me $710. I also replace all the bearings, syncros, pads and keys. $1400 total and that wasn't counting labor which was free.
Basic rebuilds don't always include bearings. I'd ask about that. Should add $200+ depending on brand.
ehillard0 I am going to do the shifter adjustment, its worth a shot. Was that an EOM mount? I've read some stories of aftermarket/poly mounts creating a lot more NVH (obviously that's the case with any bushing/mount) and I'm not sure I want any additional NVH from my transmission...
I'm starting to work at buyavette this Monday in the service dept.
Dang I may have spoken to you then! I called this morning to cancel my apt
I appreciate the info Josh. As the days go by the idea of doing it myself seems to get more and more attractive. I'll start to gather info and see if its something I can manage. I've read about the rebuild manual out there for these transmissions, is that guidance you'd recommend?
Price: $ 1,500
Price: $ 1,500
I appreciate the input Luffy, Its good to know all options.
I bought this kit:
I bought this kit:
OH and congrats on the new gig man! sorry I didn't say that sooner.
I am probably in major denial and grasping at anything that could work
FWIW, I have been reading and hearing more about the trannies in the Zs as compared to the non-Z models. I'm assuming the two have different trannies, and I'm wondering why the Z tranny seems to be more trouble prone...
Banned Scam/Spammer
No, same gear box, different ratios are the only changes. The Z is used/enjoyed more aggressively (because even off the track they are snappier and more fun than a base C5, hard to resist) which in turn uses up synchros, etc...
