Has anyone tried ebay longtube headers less than $300?
#122
The corsa sport is a pretty tame axle back I agree. That is why I wanted more sound out of mine. The sound gets loud when you get in it. But when you back off you will get some pops and bangs. I am pretty pleased with how my car sounds now when I get on it. And it goes back to its usuall quiet sound at cruising highway speed. But get on it and the headers let you know there, there.
#123
What is the final end of project expense for both time and money on this? Was there anything you had to do with this set that wouldn't be needed on a "name-brand" set?
#124
Long tubes typically mellow out the sound at low load, many of my cars got quieter just for cruise driving with them. But when the car is WOT and at load, they're significantly louder.
#125
costs wise is this
2 1/2 pipe 6 foot stick -$20
2- O2 extensions 17.99 from Amazon prime
12 stainless bolts and nuts and lock washers $25 I replaced all included bolts with kit. after mockup mainly beacuse if i wanted that stuff to come back apart I figured I had better pony up for stainless hardware. but the factory bolts with kit was adequate for assembly.
10 dollars for wiring covering that i needed to replace due to heat damage from stock manifolds.
2 12617944 chevy performance gaskets $17
other miscellaneous items like my temp sensors were not required but i advise changing them while you are there.
so i would say about 150 extra in miscellaneous parts and I have no idea what might be needed with a name brand set cause i have never installed a set and each manufacturer is going to be different in what they include
#129
Well they are performing well. And so far I am happy with the install. I have not tuned it yet. Yes my check engine light is on. But it's running real well so far. My appt with the tuner is dec 4. Believe I am going to change to the 160 tstat before I go to tuner, so I can make fan changes in the tune.
#131
Car is tuned now. I am very happy with the performance and sound out of the car now. No I do not have proof of performance gain on car, but you can tell when you mash the go fast pedal, that there is a little more pep in the car.
#132
A little more pep? I have LG Longtubes and the power gain especially torque gain is sublime. I would be making an understatement if I said I gained a ton of power.
#133
I did not want to embellish, but it did wake the car up a lot. I can not wait to get my cam and heads on, but I am torn between putting bilsteins on all 4 corners and poly bushings all the way around, or get the motor work done then do suspension and brakes.
What a fun car though!!!
#134
The gain from headers and a tune is less substantial than the gain from having a heavy passenger and full tank of gas, to no passenger and a quarter tank.
#135
Is the passenger an elephant in your example?I went from 13.2 stock to 12.68 after headers and Vararam only .. no tune... on a worse 60ft time
#136
But would you still run a 12.7 with a 225 lb. passenger and a topped off tank?
Pretty much always true that the least expensive performance improvement is a diet. Just a LOT more work than bolting on hot rod parts.
At least for me...
At least for me...
#137
Received 4,708 Likes
Lol... its WAY easier to just bolt on more go fast parts!
#138
Driver's side flange
Passenger side flange
Box was a little beat up
Both headers
All pts in box
I will lookover everything this weekend. Probably be a week or two before I begin install. Trying to figure out what I will need for install. These are the headers I posted on the first page from Amazon
Both headers
All pts in box
