Proper Oil Pressure AFTER an Oil Change?
Old 11-05-2017, 05:07 PM
Mayor111
Mayor111's Avatar
Received 1,945 Likes on 934 Posts
Default Proper Oil Pressure AFTER an Oil Change?
Hey guys,
I completed my first oil change and very proud of myself since I have zero mechanical skills.
After the oil change, I ran the car in my garage to check for leaks - NONE! Then I took the car our for a quick drive and noticed the idle pressure was around 40 and when driving it I saw it go to about 48...
Are those pressure readings all good?
Old 11-05-2017, 05:16 PM
capevettes
Support Corvetteforum!
capevettes's Avatar
Received 4,541 Likes on 2,157 Posts
2016 C2 of Year
2015 C3 of Year Finalist
Sounds fine to me. Oil pressure is always a bit higher right after an oil change. It will settle in to it's normal range quickly.
Old 11-05-2017, 05:21 PM
DDaaryl
DDaaryl's Avatar
When and if it reads wrong it's usually a defective o/p sending unit which is fun to change
Old 11-05-2017, 08:25 PM
DaDuck
DaDuck's Avatar
Default disagree
Originally Posted by Mayor111
Hey guys,
I disagree that you have zero mechanical skills.
You are at least a 2 out of 10. (no leaks!).
You would be a 1 out of 10 if you caused a leak.
You would be a zero out of 10 if you told a story about how a quick lube place did an oil change on your vette.
Dave
Old 11-05-2017, 08:34 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Dave
you were too hard on him....3 out of 10.....he didnt strip the sump bolt threads and he got the oil filter off...
and the car didnt fall on him and squash him...thats 3 for sure
doublenut9 (11-07-2017)
Old 11-05-2017, 08:38 PM
dbgoodwin
dbgoodwin's Avatar
based on the number of people I know who can't work a ratchet... definitely a 3 out of 10
Old 11-05-2017, 09:54 PM
pjdbm
pjdbm's Avatar
did you raise the rear up a few inches higher than the front?
Old 11-05-2017, 10:53 PM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
The oil pressure your car is showing seem OK to me. Mine reads about the same.
Old 11-05-2017, 11:04 PM
laurent_zo6
laurent_zo6's Avatar
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Old 11-06-2017, 09:30 AM
Mayor111
Mayor111's Avatar
Yes - the rear Jack Stands were raised three "clicks" higher than the Jack Stands in the front.
I used 2x6x24 boards between the car and the Jack Stands
The bolt was hard to twist at first, but that's because I didn't have the car high enough - raised it up some more and then I had enough room to maneuver for the proper leverage.
The filter came off with only hand pressure, although I had a filter removal tool ready to go if needed...
As of today, the floor under the car is still bone dry - no leaks!!!
Old 11-06-2017, 10:44 AM
pjdbm
pjdbm's Avatar
Great job!!!
Next you can tackle the rear gear oil change.
Easy job
Old 11-06-2017, 10:46 AM
glbeauchamp
glbeauchamp's Avatar
Another 1/2 point to you if you torqued the plug to factory spec (18 ft/lb). Spark plugs next--You can do it! By the way, your oil pressure looks good. By the by the way: Did you reset the oil life readout?
To Proper Oil Pressure AFTER an Oil Change?
Quick Reply: Proper Oil Pressure AFTER an Oil Change?
