Leaking fluid out of bellhousing .... is it the slave cylinder? 2002 Corvette
Hi guys! New to the forum! I have a C-5 Corvette 2002....lost my clutch pedal and now I see fluid dripping out of the bell housing so more than likely it’s my slave cylinder ...... is it possible that it’s anything else? I see slave cylinders are common problem and I have 85,000 miles on the car
Are there any good directions to doing something like this on the floor? thanks so much
Enjoy while you can.
Received 2,684 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Welcome aboard. Try posting here for better results, good luck:
https://www.corvetteforum.com/forums/c5-tech-1/
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Welcome , Moving to C5, lots of people to help there !
Ang (11-24-2017)
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Welcome to the Forum.
In addition to the slave cylinder it could also be a simple leak in a hydraulic line. Check the line that runs between the master cylinder and the bottom of the reservoir. IIRC this line just slips over each of these fittings without clamps or retainers, so it’s possible the line has slipped away enough to cause a small leak.
The MC or line could also have a crack from age.
Good luck!
Good luck!
Ang (11-24-2017)
Received 19,274 Likes
'20-'21-'22-'23-'24
This has been reposted in C5 Tech. Closing this thread down.
