C6 knop on MGW Short shift C5
Old 12-02-2017, 06:23 PM
Emilj96
2nd Gear
Emilj96's Avatar
Default C6 knop on MGW Short shift C5
Hey
I have MGW short shift with race knop on my c5 -04. How it works with c6 6-speed knop 08-13 on mine mgw shifter?
Old 12-02-2017, 06:36 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
you need an mgw c6 shifter shaft or there used to be a company that sold a c6 style **** that threaded onto the c5 shaft, not sure who makes it but it is not oem
Old 04-22-2018, 09:35 AM
jost6453
jost6453's Avatar
You might want to try a C4 M shift ****. It's smaller that the OE C5 ****, screws on the same, uses the same shift pattern insert, feels better, and looks great in the C6. Check it out!
Old 04-22-2018, 01:22 PM
knewblewkorvette
knewblewkorvette's Avatar
Received 2,706 Likes on 1,668 Posts
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
when you order a MGW shifter, there is an option on what style of shift **** you want to use. Contact them for the different style shaft.
Old 04-22-2018, 01:44 PM
FYRARMS
FYRARMS's Avatar
Received 3,233 Likes on 1,589 Posts
If anyone with an MGW shifter is interested, I have an MGW C6 shifter lever and OEM leather C6 **** available. It will thread directly into your current MGW shifter adapter.
To C6 knop on MGW Short shift C5
Quick Reply: C6 knop on MGW Short shift C5
