Engine choking after or in a rain storm
Hi all,
I have a Airaid air filter on my 2003 C5. After the car is parked out in the rain water coming down the hood flows directly down into the filter through the front gap of the hood.
Then when I drive it home merging unto a freeway under hard acceleration the engine cuts out unless I let off the gas. It eventually evens out after what I am guessing the filter gets rid of the water.
Now yesterday during a heavy rain it would do that just under normal driving.
Anyone Have/Had and offer a fix?
Doc
Doc
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
That's a good way to hydrolock an engine.
This might help:
https://www.ebay.com/itm/C5-Corvette...53.m1438.l2649
Dr. Doug (01-10-2018)
put stock air box back on in lousy weather.
Been getting some heavy rain the past few days, haven't had any issues with my Vararam fortunately. Seems like quite a crappy design if it's letting your engine get too much water in the rain. Might be time to consider a different CAI, especially if you're going to continue driving it in the rain and leaving it outside.
Callaway Honker would be a good (pretty much only) California legal intake.
My Airaid filter gave me the same problem. Get one of these type and problem solved.
http://www.westcoastcorvette.com/p-7...04-c5-z06.aspx
WCC JOE (01-10-2018)
Take a good look at it and decide how water is getting in. Shut the hood when everything is very dry and use a hose to splash water into the engine bay to see how it gets in and from what angles.
Then take corrective measures. Cut a piece of aluminum or plastic to cover areas you notice the water is splashing in. You can alternatively move the air filter, add plumbing curves or a trap door water to collect and release, like a factory box.
Or just keep the factory box in the car because it does all of that.
Is the AirRaid a non-oiling type? An oiled filter media should have one advantage; repelling water. But a hood seal should fix that up.
Received 19,286 Likes
'20-'21-'22-'23-'24
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
Here is the stuff:
https://www.lowes.com/pd/M-D-0-36-in...EaAkJiEALw_wcB
or
https://www.lowes.com/pd/M-D-10-ft-B...rstrip/1038917
or
