Ever had tranny fluid leak once and never again?
Received 1,679 Likes
I’ve actually got a thread about my issue in the Tech area, but I know several CF members don’t usually hang out in the Tech section.
Anyway, my tranny leaked a few ounces after merely starting it, backing it up, then pulling into a different garage area for about 2 hours. Definitely red transmission fluid.
Main thread with details w/pics here - https://www.corvetteforum.com/forums...-chime-in.html
Since then, drove it easy and then drove it hard for about 20 minutes, parked it and have been watching for drips ever since...but no leaks for hours now. Any input would be appreciated.
Some people have had C5's with overfilled transmissions. In this case maybe your trans leaked excess fluid from the vent tube, then once purged of the extra fluid it won't leak anymore. This could explain your leaking situation. Or it could have been overfilled on a trans fluid change.
FX VETTE (01-29-2018)
SG Lou (01-29-2018)
Thanks Striper. 14 hours later and no leaks. I have had the car for the last 6k miles and have never messed with the transmission. I seriously doubt the previous owners ever had the fluid changed, no records of it anyway. Is it possible that it has ben overfilled and now 15 years later and 45k miles it decided to let the excess go?
My plan is to put it up on ramps and jack stands, hit that whole area with degreaser/hose it off or clean it up with brake cleaner and see if I can tell exactly where it is coming from.
SG Lou (01-29-2018)
Maybe it stopped leaking because it's empty now. (lol).
If you do get it up on stands, you should check the fluid level. And, since you said you doubted the previous owners had ever changed it, maybe it's a good idea to do that after you ensure it's not leaking from somewhere.
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Twice I've had drips on the floor that i couldn't identify and tech couldn't find anything. Now we find a pinhole in a heater hose which is on the same area as the drip.
I’m at a total loss Lou, I don’t know much about transmissions. It’s a bit gunked up in that general area where I saw the red drips, so I’m guessing this has been going on for a while. The thing I really don’t understand is the amount of fluid that leaked on the garage floor within 2 hours and then now nothing at all. Especially when all I did was back it up from one garage spot and move it to another.
Mine seemed to leak the most when it was driven at higher speeds. Not so much when parked or lower speeds. Good luck and let us know how it turns out.
FX VETTE (01-31-2018)
I ran my issue by a guy who runs a reputable tranny shop in a city nearby. He said the amount of fluid that leaked was minimal and could have been due to venting. He also offered to inspect it for free.
I'm still going to clean it up good this weekend and monitor it. Then probably take it by his shop after a bit of monitoring. It's due for a tranny fluid and filter change in 5k anyway.
Thanks to all who replied. I know most CF members don't even click on threads with transmission issues, so your input is much appreciated.
