open recall 14 years old
In doing some research on the 1998 I bought last July, I found that the car has an open recall for "electronic column lock". I'm aware of issues that some have had with this and want to know: Should I take it to a dealer and have the recall repair performed by GM - or will they even do it at this point 14 years later. Or, since there hasn't ever been a problem since 1998 just do nothing? Or, buy and install the after market attachment that prevents the column from locking.
Appreciate the advice as always...
Received 19,302 Likes
'20-'21-'22-'23-'24
SG Lou (08-10-2018)
Have you checked if the previous owner(s) already corrected this? If not, the only real solution for this is the LMC5.
You would most likely would have had to pay for that recall.
The statute of limitations, according to NHTSA, for all no-charge recall repairs is 10 years from the original sale date of the vehicle. However, one exception is tires. Tire recall repairs must be completed within 60 days of receiving a recall notice.
Location: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
However, I will add from my own experience on my MN6 2000, that I had it for 3 years when I got the recall notification, and NEVER had a problem with it before. Two times I had it towed to a local Chevy dealership to get it fixed because of the dreaded "Pull key, wait 10 seconds" BS after they worked their dealership magic.
If I had to do it all over again, knowing what I know now, I would've just left it alone but, I will say the LMC5 is the best remedy and the least painful route to go in fixing the problem.
bc6152 (02-19-2018)
Pro Mechanic
No "limit" on GM (or any mfg for that matter) safety recalls...they can be done anytime, free of charge to customer. Parts availability might be another matter, however, depending upon how old the recall is.
That said, in this case the advice you got already is spot on...the recall will NOT fix the issue. Get the LMC5 installed BEFORE you wish you had...
bc6152 (02-19-2018)
Corvette C5 Enthusiast
Received 3,054 Likes
Do not take your car to a dealer for the column lock recall. It is well documented here and on other forums that the GM fix does not work and will cause other problems.
Your best and easiest solution is to install a LMC5. Here is the link:
http://www.complianceparts.com/
Or install a column lock bypass:
Here are some helpful links.
How to install a Column Lock Bypass:
http://97vette.com/howto/columnlock/index.html
http://www.ls1howto.com/index.php?article=24
You can get a CLB from one of these vendors:
http://www.rpidesigns.com/shop/item.aspx?itemid=3138
http://www.westcoastcorvette.com/p-4...FYdQ7AodBB8Aaw
I have installed both and without issues,
Was looking for current post re: "column lock recall" as I received a mailed notice, and a phone recording on my 2000. I installed a column lock bypass back in '03 and have had zero problems to date, but I thought it
odd they're very concerned 18 yrs. later.
Banned Scam/Spammer
Received 1,319 Likes
LMC5 isn’t what I’d put in.
This is literally plug and play in the drivers knee panel and much better than splicing in wires like the lmc5.
They both do the same thing, just one is easier than the other to install
Weve installed maybe 250+ of these at the shop and zero issues. Also comes with the jumper to unlock the column (if it’s locked before you do the install).
http://www.fullthrottlecorvette.com/...le_p_3295.html
I installed the LMC5. I had no issues before, and still don't now. The previous owner (Dad) had one of the column lock recalls done, but no idea which one.
Speaking of recalls, the parts may no longer be available. When I took it in attempting to find out what exactly was done for the recall, they discovered there was still an open recall for the twisting seatbelt. This is a safety issue, so should still be honored. The part is no longer available, so I can't get it done.
I had the GM "final" fix done by the dealer at no cost to me in 2010 - car was a '98 MN6, built in '97. My point to them was that I had had their previous fixes done, so it should not have failed. Chevrolet apparently agreed and paid the tab.
The final fix, by the way was to remove the locking mechanism, so no column lock. And no problems since - I would not expect there to be, given the locking "bits" are gone.
