★Quiet Down Your 97-04 Interior in Seconds!! / Blockit Sound Deadener - FREE S&H!!!!!
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
★Now Available for the C5 Coupe, Convertible & the Z06!
Order Now and Received FREE Shipping & Handling!! The Box is large so you save BIG!
There's nothing sexy about road, tire and interior noise!
Simply place the pre cut BLOCKIT Quick & Quiet sound deadening mats right over your existing carpet! One piece is cut for the cargo area and one piece for behind each seat.
There's no adhesive so your NOT permanently gluing weight to your car!
This is NOT a thin single layered mat. The BLOCKIT is a unique combination of 4 infused layers of real acoustical soundproofing. It measures 1" thick! You loose no room in your cargo or trunk area because the Blockit squeezes down to 1/8"!
Its patent pending design absorbs and suppresses unpleasant sounds that leak into your interiors cabin. It’s perfect for taking that annoying edge off tire / road noise & some aftermarket exhausts. But not to worry, your sweet exausht note still comes trough when you get on it! Great for blue tooth or just having a conversation with a passenger.
The durable UV protected top layer looks great and allows you to still use your cargo area. Feel free to place an aftermarket cargo mat on top!
Since there is no adhesive it’s removable. So feel free to take the Blockit out on track events. Install back for the trip home.
The BLOCKIT also helps keep your cargo/trunk area cooler by suppressing heat from underneath too!
All layers are bonded together using a unique infusion process. No glue means no toxic smell. Made in the USA! Raw materials are from the USA Too! Manufactured under strict ISO 9001-2008 standards! Patent Pending!
Picture below shows where the 2 pieces behind the seat go:
* Reduce interior noise in seconds! Just place it in & go!
* Great for tire/road noise & some aftermarket exhausts
* Pre - cut & shaped! No adhesive! Lays right over your factory carpet.
* No ripping up your carpet/interior.
* 4 layers of REAL acoustical soundproofing materials
* Unique infusing bonding of the layers so there's NO glue!
* 1" inch thick! Easily compresses down to 1/8" so you loose no cargo room!
* 3 Piece pre-cut Kit. (4 piece for the Z06)
* Great for long trips.
* Textured UV protected top layer is durable & looks great.
* Made in the USA!
* Manufactured under strict ISO 9001-2008 standards!
* So effective we filed for a patent!
Order Now and Received FREE Shipping & Handling!! The Box is large so you save BIG! [/CENTER]
________________________________________ ______________
C5 Coupe
★To Order Securely, Click Here:
http://www.tkoperformance.com/1997-2...upe_p_366.html
C5 Convertible & Non Z06 FRC
http://www.tkoperformance.com/98-04-...ts_p_1991.html
C5 Z06
http://www.tkoperformance.com/2001-2...ats_p_635.html
Feel free to contact us if you have any questions!!
Sales@tkoperformance or 1800 778 9898 9-4:30 pm est
Thank you
Below are some comments from various Corvette forum members
I installed the 3 piece system and finally got a chance to do a test drive this evening. I was very pleasantly surprised how well it worked as the improvement was immediately noticeable. The noise level inside the cabin was reduced and I had to lower the radio volume since it was so much easier to hear. I can still hear the nice sound of the engine & exhaust, but without the annoying road noises. Very pleased with this purchase.
I installed the Blockit sound insulation mat and the behind the seat panels this weekend and I am very impressed. The mat just goes in the hatch area and the fit is excellent. I installed the two panels that go behind the seats behind the carpet. The carpet in that area is not tacked down so it is easy to do.
The mat looks very polished in the rear cargo area so I don't think that I will add an aftermarket cargo mat on top of it.
While commuting to work this morning on the freeway I really did notice a difference. I did not have to crank the radio way up and the voices and music were much clearer.
If you are looking for a real easy sound insulation solution I would recommend this product.
I just put one in my '05 coupe. The difference in interior sound was instantly noticable. After cranking it up I had to put the window down a little to make sure the engine was running OK.
It did however, take me double the 30 second recommended install time, due to me flopping it in there upside down and then having to take it out and flip it over because I didn't read the instructions.
I got mine yesterday and installed it last night.
First drive to work this morning and I can tell you it makes a big difference. Those that say it doesn't must have some really frickn' loud exhausts.
It took the resonance away that the road puts through the rear hatch area (hatch floor, plastic) and the road noise from the tires is probably cut in half.
There's also a noticeable "quietness" inside the rear now that I never had before. I always had that "white noise" behind my head from all the noises coming from the rear hatch area. Now it sounds like the entire car is quieter.
It made such a difference I am no longer worried about putting dynamat or peel and seal in my car. I will however still do the peel and seal on the floor boards under the car because now that the rear is so much quiter I hear road noise from under the car... lol.
Overall, it's a great buy and I'm glad I bought mine!!
To start with, I am not a vender and do not sell these things, but WOW! What a difference. I have an 05 vert with borla stingers and love the sound. But on the interstate and highway speeds, the car is just kind of loud. Not just from the exhaust, but from road noise. So I bought the new "blockit' insolation kit sold here on the forum. Not the kind that requires you to remove the carpet or anything. Just put two pads behind the seats and one pad in you truck, or cargo area for a coupe. I drove my car at 70+ MPH for a good ways last night and WOW!!! Much smoother and peacefull sound. The stereo sounded better and the car just seems so much quieter in the cab area. I have had a C6 coupe and now have a C6 vert, and I promise you, this thing works! Just wanted to shout out a nice mod.
I was at Carlisle and the Blockit was sold out, so I bought the demo kit that was inside the Corvette parked under the TKO tent. In my opinion, it was worth it because it works. My C6 is very loud, as it is cammed, etc., with headers & NPP. It has an annoying low rpm drone. With muffler flaps open it is unbearable for cruising below 1,950 rpms. Even with flaps closed, the drone was very annoying below 1,950. Most of my cruising is between 1,700 and 1,950 rpms in 6th gear with 4.10 gears. With the blockit installed, the drone is gone at these rpms with flaps closed. Not just reduced, but gone. Below 1,700 drone is reduced to a bearable level.
With muffler flaps open the drone is reduced with the kit, but still louder than my comfort level. But it's a moot point now.
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
Installed on my C7 Z06. TRANSFORMATIONAL! The reduction in tire noise is astonishing. Being an engineer I had planned to use my laboratory dB meter to measure noise levels with and without the TKO Blockit kit. As it turns out there is no need to do so because the noise reduction is truly dramatic. This kit is a "must have" for all but deaf C7 owners. I had a '14 Z51 which had hellacious tire noise. I was exhausted after driving it for 3-4 hours. The '15 Z06 was significantly quieter and rides more smoothly....think Chevy vehicle engineers softened the suspension bushings. Seems to be well known that the '15 is a quieter car. Just can't believe how such a relatively inexpensive and easily installed kit can be so effective. I could now drive the car across country....yes, it's that good.
Well, I had a chance to test drive my car on some roads that previously had some serious tire noise due to the road conditions. For the ease of installation and simpleness of the product; I'm very pleased with the it. I was able to lower my radio volume from where it used to be, and hold conversations without raising my voice. In fact I am now aware of other noises that I hadn't previously heard.
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
Tom
Received my set of sound deadeners yesterday and promptly installed them in about 10 minutes.
Started the car in my garage and could hardly hear the exhaust with the windows up. Backed it outside ( a lot of snow here now ) and tried the same thing, windows down ,windows up. I will not get to take the Z06 out until spring, but I can tell you that there is a substantial difference in the noise factor just sitting in the car and listening to it run.
Great product. Can't wait to do a more extensive test in the spring, but initially this seems to be a great product !!
Many thanks,
Dave
Many thanks,
Dave
Just got my Blockit mats today and did a roadtest on the concrete I16 around Savannah and a couple miles on local black top.
Super easy install - drop in and forget it. I have a coupe.
Big rear mat had the slits for rings.
Put my Stingray logo rear carpet on top of the mat and also put the mats behind the seats.
I can tell a difference in noise ; can hear the radio better and believe a long cruise will be far more pleasant.
I have the Blockit mats. My wife can hear like you wouldn't believe. She is the perfect test for these. She stated to me that there was a significant difference in sound reduction. That's good enough for me. I thought there was a difference too, but I didn't want to rule out wishful thinking on my part so I had her listen before and after.
I put it in my 2016 Z06 last week and the difference is very noticeable. Less tire noise, radio volume setting is lower now and much more enjoyable. As another poster noted the exhaust sound now stands out more; my Z06 exhaust is normally set to track mode.
I did notice the action of the Bose audio pilot (auto volume compensation) is much more noticeable now and I turned it off.
obviously super simple to put install, in a 10 min trip to the store... noticeably quieter. i have LTH, high flow cats, and factory npp. to me it sounded like i had the flaps closed.. maybe even more quiet than that.
…… is it worth the $230?? to me yeah, because i am lazy don't want to pull all the carpet out.... so with that being said, money well spent to me
Thank you!!
__________________
Serving The Corvette Forum For 21 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
We have C5 Coupe and Convertibles in stock.
Z06 kits are o.o. stock. But we will have them in stock shortly.
Thank you!
Thank you!
All orders from over the weekend will ship today! Big storm is coming so we want these out!
Thank you for your business!
I have a 2004 Z06 with an after market partition. I'm assuming I would have to cut the large piece so that there is one part on one side of my partition and one on the other. Has anyone installed this that way that you are aware of?
However if you had to cut it, a straight edge /box cutter (with a big blade) cuts it like butter.
Thank you for the orders! All in stock. All orders leave tomorrow! We will email the tracking to your address from your account. If you ordered yesterday or today and you don't see a tracking number please contact us.
DeadMats.
Awesome product for damping. Stops vibration & noise dead. Lighter and thinner then other products.
You might not need as much as you think with this product. So call us first before you purchase.
(2) Sheets 18"x32" Click Here
(5) Sheets Click Here
(9) Sheets Click Here
One of the hottest kits we created is The Blockit and two 18"x32" sheets for behind the seat. (Combo Kit).
Check it out & read about it here Click Here
Feel free to contact us more about a sound solution for you.
So, in addition to this kit, "Has anybody installed the 18 x 32 mats below the carpet in the footwells to cut down noise coming up through the floor of the car?"
Does it add anything (more noise reduction) to the pads behind the seats and in the rear area?
Part of the sound deadening comes from the foam, and if this is compressed by anything lying on it and compressing it in the rear, does it still work as well?
So many questions before I make the plunge.
Sorry, but that kind of an answer is not going to sway me to buy your product.
I asked those questions for a reason, hoping I would get a real answer from someone.
We get it. You want to hear from someone other then us. It was understood the first time when you responded originally a few days ago (post 10).
C5 Coupe and Z06 Mats are finally done! Orders will be shipping out Thursday! Still plenty of time to make it under the tree.
hank you for your business.
Ed
Ed
As promised the Blockits are back in stock. and shipping out. Thank you for your orders and your patience.
I hope hope everyone's Christmas was fantastic! ...and now back to the grindstone. All Blockit orders will be shipping today and tomorrow. I'll be sending tracking numbers via email you provided.
Thank you!!
Thank you!!
Orders from over the weekend have shipped. All orders are the new Blockits with more sound deadener added!
Getting low on stock but we still have a few left. If you have any questions please feel free to contact us!
Orders from this week (1/26 forward) have shipped. Check your emails for fed ex tracking numbers. Thank you!
