1999 C5 hood vents or not? - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 02-22-2018, 04:18 AM
Rlb2002vette
CF Senior Member
Default 1999 C5 hood vents or not?
I need help from y'all. What are the pro's and cons of installing Treckspec three hood vents on my 1999 vette?
I'm worried what if I get caught out in a rainstorm, Ty for sharing your knowledge and wisdom.
Rlb2002vette is offline
Old 02-22-2018, 09:36 AM
Gordy M
CF Senior Member
Unless I was doing numerous autocross/HPDE/Time Trial/wheel2wheel driving there really is a reason to add the hood vents. From a cosmetic point of view, Beauty is in the eyes of the Beholder. If you like them, fine if you do not like them, fine.
Gordy M is offline
The Following User Says Thank You to Gordy M For This Useful Post:
OUTAKTRL (02-22-2018)
Old 02-22-2018, 12:28 PM
charger21
CF Senior Member
charger21's Avatar
I do not know of any cons, and I know a lot of people that have installed them. Some track cars, and some daily driven cars. Zero issues.
charger21 is offline
Old 02-22-2018, 03:27 PM
Tsumi
CF Senior Member
Tsumi's Avatar
A lot of cars have hood vents and don't have problems in the rain. Supposedly the bottom breathing intake throws a fair bit of water around the engine compartment anyways, I'll have to see if this is true the next time it rains.
Pros: reduces underhood pressure, which reduces front end lift and improves radiator airflow. Reduced lift means better handling. This is really only noticeable at high speeds (90+ mph in my estimate). It also means better MPGs, however slight. Underhood temps will also be lower.
Tsumi is online now
Old 02-22-2018, 09:25 PM
Moderator
Support Corvetteforum!
Location: Heart of Missouri Currently Own: 2003 Milestone Edition. Previously Owned: '79, '79, '84, '89, '94, '95, '99 and '00
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
For me, it is more of an issue of looks than anything else - not my cup of tea. That said, I did have an MCM hood at one time and really liked the way the vent was integrated into the hood.
But if you like the look, there is absolutely nothing wrong with that. Get them and enjoy.
As to the bottom breather funneling a lot of water into the engine compartment, the times mine has been caught in the rain I did not experience a lot of water in the engine compartment.
Vetteman Jack is offline
Old 02-23-2018, 09:30 AM
redzg
CF Senior Member
So what kind of vents are we talking about? Center hood, fender tops, all three? The question made me do a Google search -- lot's of options have been tried out there. Some look interesting.
Some don't...
redzg is offline
Old 02-23-2018, 09:55 AM
sstonebreaker
CF Senior Member
sstonebreaker's Avatar
No need to worry about the rain - way more water is going to come in from the tires and under the front than through hood vents.
sstonebreaker is offline
Old 02-23-2018, 03:17 PM
Rlb2002vette
CF Senior Member
Ty for your shared knowledge. I just like how the look, I'm not a racer.
Old 02-23-2018, 03:20 PM
Rlb2002vette
CF Senior Member
Ty , I was just curious about all the water on my engine good point about the water from the tires. Thank you
Old 02-23-2018, 03:23 PM
Rlb2002vette
CF Senior Member
Some don't...
Ty for responding to my questions. The 3 vents are made by Trackspec. One bottom center the other two are located on the hood above fender wells. Thier around $350.00 for all three. Ty
Old 02-23-2018, 03:28 PM
Rlb2002vette
CF Senior Member
Some don't...
Thank you foe resounding to my question. Thier made by Trackspec. They all together cost about $350.00. One about a third up the center of the hood then one oner each wheel wells.
Quick Reply: 1999 C5 hood vents or not?
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
