Just go my New Seat cover & Foam
Yep General Top & Trim in Saginaw, Michigan. No way I would pay them prices either.
I'm glad people are getting theirs, I ordered around January 15, still no word. 2 weeks ago they said "they guarantee they will be shipped in 24-48 hours (March 8th) and I would get a tracking number, still nothing.
Hopefully mine show up before April, but I'm not going to hold my breath.
If Vette Essentials were still around, I would have gone with them, but II is almost the only game in town unless you want OEM or Mid America Motorworks.
It would be great if you could get any info but they would have to actually respond for that to happen and it just doesn't happen.
FedEx tried to deliver today, so it did take right around 2 months. I'll go pick it up tomorrow.
EDIT: I received them today. Very nice and very pleased with the quality. They are pretty thick.
I got a response from Interior Innovations within 24 hours when my covers were taking too long. They promised they would take care of it and sure enough my covers arrived 48 hours later. Top service from them.
Here is my thread on a how-to..loaded lots of pictures and tried my best to give a good understandable description of each step.
https://www.corvetteforum.com/forums...cs-galore.html
NOTE...These pictures are loaded on Photobucket and we all know the stunt they pulled.
If you haven't already, download the Google Fix for Photobucket and you should be able to see the pictures.
https://chrome.google.com/webstore/d...kegnjbncdcliih bemealioapbifiaedg?hl=en
Oldtimer
I have my II seat covers well over a year now. Took 10 days from the final order (we were making design confirmations).
I used all new foam. Because of it's stiffness, I did some trimming.
Some use ballistic nylon, others use jute pads or other 'wire resistant' materials to protect the seat foam from the 'foam cutting wire'.
The seat backs would not hold using the plastic 'fir tree' plugs. I devised a system where I drilled an additional hole in the fiberglass near the existing one. I made an 'anchor loop' with a zip tie then used a second ziptie thru the setback holes and the loop. It allowed me to cinch it down gradually and evenly.
I also 'dulled' the forward edges of the setback bolsters with a length of neoprene tubing so the fiberglass would not push thru the foam.
Leather vs vinyl. Vinyl makes me sweat in any weather, so it's not a consideration. I think the leather quality is excellent, much better than stock.
If you're on a budget or vinyl doesn't bother you then it should be fine. I've heard that installation with vinyl goes a bit easier because it stretches more.
ToeKnee Sea (04-17-2018)
#33
#34
I bought the vinyl covers last year from Interior Innovations and put about 10,000 miles of use on them. I'm 5'9" 190lb and careful about how I enter the car and still noticed significant bolster wear on the new covers. It was bad enough that I had to replace the drivers upper cover when selling the car. If I were to do it again, I would definitely pay extra for leather, or if the colours were identical, just leather on the more used drivers seat.
#35
I did synthetic out side and leather inserts per my post photos.I still need to install the seat covers and foams. Can I reuse the back rest insert foam clips? If not where can I get those clips? I hope I don't relocate the holes and drill it like other guys have here. May be if That's the case I may reuse my old ones-seems to be in good shape.
#36
Oldtimer
I’d use new ones, but I felt the tension on the new foam would not allow them to holdj either.
As far as adding holes, once you see how much fiberglass there is, you’ll be convinced that a few more holes wont weaken it. In my case the holes were only big enough for the zip tie to go thru.
#37
Take one with you to a decent auto parts store, they will have them.
