No run flats - what tools do you carry
Old 03-09-2018, 06:27 AM
JDAN1930
JDAN1930's Avatar
Default No run flats - what tools do you carry
I know a lot of you have chose not to have run flats on your car. What type of tools do you carry? What type of jack? what type of compressor to air the tires up. Want to get some stuff together in case a road trip comes up. Hate to be stranded and not able t get things going. Im not really a fan of a can of slime so that is out.
Old 03-09-2018, 06:35 AM
capevettes
Support Corvetteforum!
capevettes's Avatar
Received 4,551 Likes on 2,160 Posts
2016 C2 of Year
2015 C3 of Year Finalist
Cell phone and a prayer. That fix a flat goop will ruin your tpm's.
Old 03-09-2018, 07:01 AM
redzg
redzg's Avatar
AAA Plus card.
Old 03-09-2018, 07:54 AM
Yokesc5
Yokesc5's Avatar
Dont have a vet yet but have carried a plug kit n air compressor , screw jack with wood block for 30 years. Red tire ropes, coming from motorcycles ,the only one that would handle the heat. Pair of dykes or single edged blade to trim the rope.
Daveinnola (05-09-2019)
Old 03-09-2018, 08:47 AM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
plug kit, compressor, dykes, needle nose pliers, hammer, SIG229 and cell phone
I tell you a trick I learned if you have space, a cordless drill...if you drill the puncture out a bit its easier to insert the plug...nothing crazy....and it helps if you have a hammer to smack that plug tool sometimes
JBB (05-09-2019)
Old 03-09-2018, 08:50 AM
Yokesc5
Yokesc5's Avatar
tee handle tool kit
Old 03-09-2018, 08:52 AM
pewter99
pewter99's Avatar
Originally Posted by Yokesc5
tee handle tool kit
Old 03-09-2018, 09:51 AM
JR-01
JR-01's Avatar
Received 1,063 Likes on 805 Posts
Wrong. Fix a flat will not harm your TPMS. The new formulas are TPMS safe. I don't understand why people want to spread false information. I have used it with absolutely no effect on TPMS. Was back on the road in a minute and had the tire patched for 15 bucks. Why make things more complicated than they need to be?
Crosis (03-11-2018)
Old 03-09-2018, 10:37 AM
jlk16188
jlk16188's Avatar
AAA card, phone and comfy shoes in case I have to walk
Old 03-09-2018, 10:52 AM
capevettes
capevettes's Avatar
2016 C2 of Year
Well excuse me. It was not my intent to spread false information. I was unaware that the new formulas would not harm the monitors. Thanks for the correction, but it could have been done in a far less accusatory manner. Actually, I'm still not sure you're correct.
Old 03-09-2018, 10:57 AM
moncal90
moncal90's Avatar
I'm still running the Michelin pilot sport ps2 for now... I'll have to change that up soon and will likely carry my cell phone and the fix a flat stuff.
Old 03-09-2018, 12:02 PM
Drewster67
Drewster67's Avatar
Plug kit, mini compressor and my AAA premium membership.
Old 03-09-2018, 12:03 PM
Drewster67
Drewster67's Avatar
Fix a flat will cause damage to the wheel if its left in there over an extended period of time. My suggestion is to not use that stuff.
Today, Fix-A-Flat uses non-flammable materials, but the rumor persists, and it’s always possible that someone, somewhere, is still manufacturing an emergency tire product that uses a flammable propellant, or that someone still has an ancient can of new old stock Fix-A-Flat laying around that still works.
Old 03-09-2018, 12:22 PM
JR-01
JR-01's Avatar
I am sure I am correct. I have used it several times in different vehicles with absolutely no effect on sensors. It really is the cheapest and fastest way to get out of a bad situation.
What is your experience?
Old 03-09-2018, 12:23 PM
grantv
grantv's Avatar
A phone... but my drives are generally short (DD mainly). If I had to drive further I'd buy a t-handle repair kit and 12V pump.
Old 03-09-2018, 12:25 PM
JR-01
JR-01's Avatar
Don't leave it in. Get tire patched as soon as possible. It really is a great product that I have used several times. My suggestion is if you need it, use it. It is the easiest solution and it does no harm.
Old 03-09-2018, 12:29 PM
tommie
tommie's Avatar
compressor, plug kit, slime, lug wrench, and small scissor jack.
I hope to never use them
To No run flats - what tools do you carry
Old 03-09-2018, 12:45 PM
Drewster67
Drewster67's Avatar
I have yet to find a tire shop that will clean the sealant from the wheel when they patch a tire. Great advice if you have the means/time to take the wheel/tire off then clean it and then reinstall.
Old 03-09-2018, 12:53 PM
JR-01
JR-01's Avatar
LOL. Really? I have never had a problem with any shop I have been to. They deal with the stuff everyday. Many people use it. It takes them about a minute to wipe the tire out. Not a big deal at all and never a complaint. They would rather wipe out a tire than mount and dismount a runflat. I have had friends that worked at tire shops and they never cried about wiping out a tire.
How many times have you used it?
It's fine if you don't want to use it, but don't scare others away. The product works and it might save someone some grief. A lot of new sports cars like Miata and Fiat don't have spares anymore and come with a can of fix a flat.
Old 03-09-2018, 01:26 PM
The Rabbi
The Rabbi's Avatar
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Fix a flat can will go dead eventually. Keep good tires and no worries.
Quick Reply: No run flats - what tools do you carry
