Since none of my real friends seem to care...
While my interior is apart waiting for my vettenuts double din bezel I decided to tackle the dim HVAC situation and replace a couple burned out bulbs. Decided since the LED place had stupid high shipping costs anyways, I should do all the switches while I'm at it.
Well the LEDs came in today, and since the switches are a lot easier than the HVAC due to not having to solder, I figured I would toss them in. Anyone who knows LED's knows that they only allow current to flow in one direction. For those not familiar: a regular bulb can be installed in either direction and it will work, an LED cannot.
Basically, you have a 50/50 shot of getting it right on the first try unless you test beforehand. I will definitely check beforehand on the HVAC bulbs, but for these I just installed and figured I would have to switch half of them, no big deal.
Anyways, I somehow went 7 for 7, which seemed impossible to me. So impossible, that my curiosity got the best of me and I literally took one out and reversed it to make sure I wasn't crazy, and sure enough it didn't work reversed.
Long story short, I'm currently charging $20 each to give out lottery numbers
Received 1,679 Likes
Dim display fix
You can get some small clamps from Harbor Freight for a buck or so, then use them to hold the resistors down while you work on each side.
Received 19,296 Likes
'20-'21-'22-'23-'24
With that kind of luck, hopefully you picked up a lottery ticket.
i actually already fixed the dim display 3 weeks ago when I got too excited and took apart my dash even though I knew my bezel wouldn't be in for a long time. Those would have been very nice...
Corvette C5 Enthusiast
sign me up!
LOL...Blind squirrel finds an acorn! Great job!
Where did you get the LEDs? Happen to have part numbers?
I got everything from oznium back in the day (2008) they still have kits I think. The thread by Tstar has the resistor values needed if you are doing red or blue. I forget what they are off the top of my head.
I'm glad my diagram is still useful! I actually used myself again when I re-did mine. Some of my resistors crossed back over and were touching positive/negative at the same time and I blew out a lot of my LEDs. I'm a LOT better at this now and everything looks right this time. Good luck!
I like the blue, but it might look a little too aftermarket for my taste.
