On the road to recovery
Old 07-13-2018, 11:43 AM
  #101
mstromquist
Support Corvetteforum!
mstromquist's Avatar
Received 3,860 Likes on 1,670 Posts
2015 C5 of the Year Winner
Glad it's all working out for you finally. Can't wait to see it sometime.
Old 07-14-2018, 06:09 PM
  #102
tommypenguin
tommypenguin's Avatar
Thanks, was finally able to attend a cars and coffee last weekend at scottsdale but was too hot to stick around. I went ahead and joined ACE and saw you on there. Will hopefully cross paths sooner than later.
Old 07-15-2018, 12:08 PM
  #103
mstromquist
Yeah, it's been pretty warm out lately so I haven't been out for a while. Glad you joined ACE, we will meet up at some point I'm sure.
Old 07-22-2018, 09:40 PM
  #104
tommypenguin
Got plates, did a custom one.
blackmachdown (07-23-2018)
Old 07-23-2018, 10:19 AM
  #105
blackmachdown
blackmachdown's Avatar
Looking sharp Nick, Can't wait to see what you put down on the dyno! I think you'll still be in the 600 rwhp zone
Old 07-23-2018, 10:45 AM
  #106
furious427
furious427's Avatar
Jesus, my car is making 440 rwhp and is fast as hell to me, I couldn't imagine 600!
Old 07-23-2018, 11:31 AM
  #107
blackmachdown
wait until 600 rwhp feels slow, then its get exponentially more expensive to go faster
Old 09-10-2018, 01:01 PM
  #108
tommypenguin
Have put 450miles on the car while the AC works great not in a rush to drive the car when it's still averaging 105degress+ outside. Don't want to dyno it till october.
It's been running really well been fine tuning things. Switched to 10w-40 oil to accommodate my bigger oil clearances on the mains and rods to get a little more oil pressure. Running an .002 and .0021 respectively for clearances. Getting 32psi or so at idle at running 212 oil temp.
Only issue I currently have is when the car is ice cold after sitting overnight and I go to start it, it will crank a couple times before starting. Doesn't matter if the battery was on a tender. When the car is warm it starts right up. If I toggle key to on/off a couple times it will start right up in the morning likely indicating a leak in the fuel some where. Two most likely culprits I have researched it could be are the check valve or possibly an injector.
Can't smell any fuel and had the injector just cleaned which makes that unlikely. The fuel filter was replaced 5k ago but I did have year old gas in the tank when starting the car after the motor rebuild. Ordered a can of bg 44k and am going to give that a shot. Have taken many logs, afr is good, fuel pressure when driving is good. Going to keep on fighting the good fight and try and get everything perfect. Don't want to hit the dyno until next month after the new baby is here and temps cool down into the 80s.
Old 10-09-2018, 02:18 PM
  #109
tommypenguin
Haven't been able to isolate my hard cold start culprit. Everything else has seemed good and logged well. Tomorrow is judgement day on the dyno. Only thing I care about at the moment is reliability. Would be totally happy with 400whp anything more is gravy. With having my second kid it's going to be challenging to find time to do an oil change in the next year let alone anything really time consuming. Wish me luck and pray that I don't blow it up tomorrow.
Old 10-09-2018, 02:37 PM
  #110
blackmachdown
Got my fingers crossed for you Nick, I think you’ll still be in the 600s
Old 10-09-2018, 06:30 PM
  #111
tommypenguin
At 8.6:1 compression and pump gas at 10psi I think I'll be lucky to crack 500whp. We will see.
Old 10-10-2018, 09:43 PM
  #112
tommypenguin
Ralph, you should buy a lotto ticket sir. Will have start calling you nostradamus, You hit the nail on the head.
Old 10-11-2018, 02:51 PM
  #113
blackmachdown
congrats man, looks like you are ready to finally put miles on this bad vette!
Old 10-11-2018, 08:20 PM
  #114
tommypenguin
That's the Idea, doing an oil change today and probably redo my wiring and halos for the headlights. Think this thread has run its course and am finally recovered from this year and half journey.
Quick Reply: On the road to recovery
