***New LED fog light from Radioflyer Innovations***
#41
Mine were delivered today as well. Can't wait to get these in but it will be a few weeks. I'll do them while changing my corner lights. Can you guys post pics after your install.
#42
when will the next batch be made that has the right polarity? and the quantity to order is 1 for both lights, is that correct?
#43
Received mine today with the custom bent paper clip! Love it!
#44
Received my "second batch" led fogs a couple days ago, today I had a few minutes to install them. Install was simple except one thing.... I only did one side initially and the bulb didn't light up when I tested it so I plugged it into the other side, which I hadn't yet reversed the factory plug. Turns out, my second batch lights weren't reversed polarity.
Hope this helps somebody.
Thanks Radioflyer for yet another awesome product. Can't wait for an LED ACA conversion
#45
Mine came in on Thursday and I got home this afternoon in time to install them. Turns out mine were not reversed polarity either. Simple plug and play. Glad I read your message first before I went to the trouble of switching the connectors.
They look and perform just like everyone else's in this thread, awesome. I do have a fitment issue with my fogs I have to sort out - the housings are not centered in the opening, resulting in a bigger cutoff than they should be, and the right one is angled up slightly. But I would not have know that if not for these far superior LED bulbs. Very happy!
#46
Supporting Vendor
The adjustments are an easy fix.
to center in housing, loosen the 10mm hex bolt that holds the fog light frame to the cross member. Adjust and when satisfied, tighten the bolt.
Vertical adjustment is a simple torx 15 accessed from the front of the car.
#47
Glad to hear.
#48
Installed mine this evening....I couldn't wait. Turns out, my second batch lights weren't reversed polarity as well....just plug & play! If you haven't purchased these, I strongly suggest you do. By far the best mod for the least buck! These are awesome! Thanks George!...PS, thanks for the paper clip!
A month or so ago, I replaced my factory fog 899's with a set of Anzo Super White 885's. The difference was like night and day. Made a huge difference over stock. Here's a pic of the 885's from 12' down my driveway. Nice cutoff with a clean light.
I actually enjoyed these lights as it made the night time drives so much more enjoyable vs. the factory 899's. This evening, I replaced the left side Anzo 885's with the light from Radioflyer....huge difference in the output as well as the cutoff.
Now with both lights replaced....fogs only!
Here's a pic in the neighborhood with only the new fogs....could almost drive w/o headlights.
Here with the fogs and headlights....Silverstar ZXE 9006 which I thought were a nice white hue until I added the fogs....(guess I've gotta update the headlights....LOL)
A few more pics....
A few more pics....
#49
Just installed mine. Just as the others have said... 20 minutes and done. Mine were Not reverse polarity either. Plug & Play. Now I’m just waiting for it to get dark so I can see the upgrade. Excellent Product !!!
#50
Supporting Vendor
Hmmm, i'm starting to think that the 98 test car may have had backwards wiring. I will continue to include the pin release tool (funky paperclip) for all future orders. Customers should test the lights BEFORE tinkering with polarity.
#52
I do have an "Official" Radio Flyer Reverse Polarity Tool (Brand New/Never Used) available for purchase for anyone interested.
#53
Supporting Vendor
option 1) If you have skinny forearms and good dexterity, you can get to them with the headlights up and headlight shrouds removed.
option 1a) If you have bigger forearms, remove the headlight cover and the headlight hinge bolts.
option 2) With the car lifted on ramps or jacks, remove the lower access panel. (wearing safety glasses is recommended as crap WILL fall in your face)
#55
#58
Running Guns & Moonshine
The bulbs in Manteca's fogs - are those the same 4000lm? Does that mean 4000k color? Is there a 5000k available?
I've got the nose in the air for other things at the moment and was going to toss these in and thought to myself... wait a tick... if these are going to be yellow hue, maybe I want to swap out for pure white to match my Luminator kit. Then I could also use the fogs as low beams if they are as good as shown.
#59
Supporting Vendor
