Rear hatch lights fuse number
Hi
I need to turn off my rear hatch lights. Is there a fuse I can pull to do this? If not, how can I get to the bulbs to pull them out? Thanks
Looks like micro relay 42 located in passenger footwell fuse block. But it also looks like that relay controls all the courtesy lights. I changed the bulbs in mine but I can't recall right now how they came out. I'll look tomorrow if no one advises by then.
MtnLuvr (06-14-2018)
They're held in by a clip. You can either try to pull them up and over the carpet wall (there's a bit of a gap up top), brute force it out and potentially risk breaking the clips, or try to get a screwdriver in one side to press in the clip. Personally I find pulling them up and over to be the easiest. Once they're out, you can easily remove the bulb. They're in a socket holder that twists and pulls off.
