C5 of the Year Competition for 2018
#44
Pro Mechanic
optiman (07-11-2018)
tbrent (07-13-2018)
tbrent (07-13-2018)
#52
Received 1,679 Likes
#56
My 2002 C5Z...
Current Mod List: C6Z Reproduction 18x10.5 +56 Wheels, Toyo Proxes 295/35ZR18 Tires (All 4 corners), BAER Crossdrilled Rotors, HAWK Black Brake Pads, Russell Stainless Braided Brake Lines, 1-7/8" Kooks Longtubes, Kooks 3" Catless X pipe, B&B Dual Tip Bullet Catback, Aldan American Coilovers, Eibach Sway Bars w/ Adjustable End Links, PFADT Polygraphite Bushings, HINSON Polyurethane Engine and Diff Mounts, RAM Clutch Master, RAM Slave Cylinder, RAM -3AN Master/Slave Line, RAM Extended Bleeder, Quicktime SFI Steel Bellhousing, ACT SFI Lightweight Flywheel, ACT SFI Lightweight Clutch and Pressure Plate, TPS Motorsports Tunnel Brace, Rebuilt Torque Tube with Timken Bearings and GM Couplers, MURICA Performance WILD build T56 Transmission, MURICA Performance WILD build 3 rib differential, HURST Billet Plus Short Shifter, Hoosier PE Transmission/Differential Brace, Racetronix Fuel Pump and Full EVAP and EGR Deletes.
More to come...
c5vetteguy (07-11-2018)
#60
Still only 37K miles but all hard miles
