A&A Vortech C5 Supercharger Build Thread by Toys4Life C5
Old 01-13-2019, 03:05 PM
  #181
tabbruzz
tabbruzz's Avatar
Originally Posted by aaronc7
It's right up against the condenser.... maybe not directly touching, but there is no space for anything between. The intercooler is in the way if you try to move it away from the condenser. You might have to move the tranny cooler to the driver side or lower it or something....
that sucks...well, I was kinda of expecting that I guess...thanks for the info...
Old 01-17-2019, 08:13 PM
  #182
Toys4Life C5
Toys4Life C5's Avatar
Received 1,248 Likes on 546 Posts
St. Jude Donor '21
Hey guys sorry for the back and forth on this but I think the coupler I ordered will work great.
Finally got to spend some time with it today and the TB side is loose but once you start to turn the clamp on it it's fine. I will run this. The extra inch in length makes fitment way easier
I went back and edited previous posts about it not fitting to avoid confusion
​Part number: HPS HTSR-350-400-L4-BLK
Are you using a Cobalt SS MAP sensor with your Speed Density tune? If so, did you swap it in place of your stock one which I believe is tucked on the back of the intake manifold towards the firewall?
Old 01-17-2019, 09:06 PM
  #183
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
I had a cobalt sensor in mine for awhile... you will have to shave one side down to allow the tab on the intake to hold it but other than that it fits like stock
Old 01-17-2019, 09:44 PM
  #184
aaronc7
aaronc7's Avatar
Yes, I use the cobalt SS sensor. Here is part number and pic showing the tabs. I just used a little sandpaper wheel on a dremel to file it down. It feels a little 'loose' in there (stock one probably was too). But for our relatively low boost levels I bet it's OK. I might do a boost leak test one day.
Toys4Life C5 (01-18-2019)
Old 01-18-2019, 10:19 AM
  #185
Toys4Life C5
St. Jude Donor '21
Yes, I use the cobalt SS sensor. Here is part number and pic showing the tabs. I just used a little sandpaper wheel on a dremel to file it down. It feels a little 'loose' in there (stock one probably was too). But for our relatively low boost levels I bet it's OK. I might do a boost leak test one day. Also, which one is the cobalt sensor - right or left?
From the limited research I have done, sounds kind of tricky to get even a smaller hand back there to remove the old one and install the new one without removing the intake mainfold. Do you concur?
Old 01-18-2019, 12:54 PM
  #186
neutron82
neutron82's Avatar
it's possible to do with the intake on, I've done it, but it would be easier if you already have the intake off... not sure I would remove it just for that reason though
Old 01-18-2019, 03:23 PM
  #187
aaronc7
aaronc7's Avatar
I did it, it was a pain to remove... I recommend keeping the wiring attached to the sensor when you remove it, I did not and when it broke loose, it was 'lost' in no-man's land for awhile but I was finally able to fish it out.
Putting it back in, I put a little lube on the tip so to speak, and it will take a little fiddling around, but it wasn't too bad. Worst thing for me was not being able to confirm 100% that it was fully seated because you can't actually see it. I will definitely double check the next time the intake comes off..but I'm in no rush.
(basically concur with neutron)
Old 01-18-2019, 09:06 PM
  #188
tabbruzz
tabbruzz's Avatar
Does the new sensor work as normal if I just do the swap in case I decide to go speed density...rather have it in there so o have choices
Old 01-18-2019, 10:47 PM
  #189
grassblaster
grassblaster's Avatar
I broke the plastic piece on the bottom of the intercooler.
what material is that .ade out of?
Or where can I buy that plastic piece?
Old 01-19-2019, 09:32 AM
  #190
tabbruzz
tabbruzz's Avatar
looks to be some type of abs plastic. Can't you just order a new one from a&a?
Old 01-19-2019, 09:48 AM
  #191
aaronc7
aaronc7's Avatar
It works as normal as long as you change a couple settings in the tune to account for the new sensor. If you swap without changing the tune, it won't work right because it will be reporting false manifold pressure information.
Old 01-19-2019, 11:31 AM
  #192
tabbruzz
tabbruzz's Avatar
ok, figures....any idea on what the tune settings are? If you have ti change the OS setting which one is it? 2 bar?
Old 01-19-2019, 11:43 AM
  #193
aaronc7
aaronc7's Avatar
The tables have what they call a "scaler" and "offset" value for calibrating the MAP. Stock is ~ 95/10. 2 bar settings are 200/8, but I've also seen 195/10 used...both will work fine.
You can run SD on stock OS technically, by failing the MAF, but it will default to low octane table and might be a few other small limitations. The custom OS avoids those issues and opens up VE/timing tables in the 100+ kPa range.
I use efilive, but yes it's basically just the "2 bar" OS, which also has some extra nice functionality intended for SD tune. But on EFIlive at least there is nothing holding you back from running a custom 2 bar OS and keeping the MAF too
Old 01-19-2019, 04:40 PM
  #194
tabbruzz
tabbruzz's Avatar
ok, perfect...I will take a look..thank you
Old 01-19-2019, 07:01 PM
  #195
Toys4Life C5
St. Jude Donor '21
Just don't get into any boost with the stock OS and 1 bar in S-D mode. That would be bad.
Old 01-19-2019, 07:57 PM
  #196
tabbruzz
tabbruzz's Avatar
yes, I dont plan on getting into any boost until it hits the dyno and gets tuned...i may just buy a map sensor and bring it to the tuners..
Old 01-20-2019, 09:48 AM
  #197
grassblaster
I looked a while ago I didnt see it.
To A&A Vortech C5 Supercharger Build Thread by Toys4Life C5
Old 01-20-2019, 09:52 AM
  #198
Toys4Life C5
St. Jude Donor '21
Just call, josh or andy will hook you up.
Old 01-20-2019, 10:37 AM
  #199
grassblaster
I have a laser cutter at work.
i'll have to call them and see what they say. I'll need that extra air grab for sure !!! lol
Old 02-02-2019, 10:31 AM
  #200
tabbruzz
tabbruzz's Avatar
see if these guys have anything that will work, http://www.siliconeintakes.com/
guys, I see racetronix now carries silicon couplers. I wonder if any of their sizes would work...
Quick Reply: A&A Vortech C5 Supercharger Build Thread by Toys4Life C5
