A&A Vortech C5 Supercharger Build Thread by Toys4Life C5
#81
Received 1,248 Likes
St. Jude Donor '21
You TUNE the set up. If the set up has imitations you TUNE for that. Thats why I said I said you need a good tuner. You do not have to spin a centri to 6k plus to take advantage of it at all. I make 2 pounds of boost at 2.6k and 10.6 at 6k with a TI, thats enough to make good power and have a ton of fun. No need to ring out a centri unless youre trying to get the most out of it or racing.
BUT - It pulls so hard at 6k - even with a stock cam, heads & without headers. It would take a ton of willpower IMO not to pull to 6500 (plus you are leaving a TON of HP on the table. Some people pull to 7k - seems risky to me - even with the later & better rod bolts....
#82
St. Jude Donor '21
you're gonna have to change the clutch if you really want to enjoy that setup to it's full potential and be able to shift super fast at whatever rpm you want, I know it isn't the most fun job but it has to be done... when you did the street tuning were you using 4th gear to tune wot?... mine has been street tuned many times with me driving and tuner in the passenger seat and 4th is always used, that will put the most load on the car and you can creep up on the tune to make sure you have no knock... you need to run it all the way to the end of 4th though and not everyone is comfortable running the car up to 160ish on the highway and I understand that so in those cases a dyno would be needed... just curious if that's why you saw some knock at the track in 3rd and 4th... you could also add a meth kit to handle that issue instead of pulling timing... manton makes some really nice 11/32" pushrods if you don't mind spending a little more but some standard 5/16" chromoly's would definitely be better than stock... a good quality beehive spring like pac would also work really well with a stock to mild/medium sized cam and have good valve control, duals would be overkill in my opinion
#83
#84
So I see what both you guys are saying. So for arguments sake, if I only have my shift points set to 6000 1-2, 6000, 2-3, and 5900 3- 4 should i be concerned with my rod bolts? Do you guys really weld your water pump pulley and replace you power steering pulley? Would I really need to if I limit my shift points as mentioned? I did buy new valve springs, power bond balancer and new alternator bracket just as precations... Again I and shooting for a conservation tune. Not race much if any....
#85
I respect your opinion & that is what this forum is for.
My car seems to really take off around 4k.
#86
I replaced my power steering pulley with one from Turn One. The c6 is cheaper and metal. Pin the crank for sure. I did not weld my water pump.
Just leave your shift points where they are and tune the fuel and timing. 75 Lambda WOT (11AFR) and set timing to 12 degrees WOT would be conservative start. I would read plugs and throw it on the dyno if you have time to see what the car truly wants.
#87
Totally agree about the clutch. I think I am going to go with the RST. Good MN winter project. NO 4th gear tuning on the street for me (:-). I only get into 4th WOT at the track. I think I saw knock in 3rd and 4th at the track because the longer you are in WOT, the hotter the combustion chamber temps (and inlet air temps) will get. On the street I am never in WOT that long so I can get away with a little more timing with 93 octane. I am going to mix up some E40 next spring (instead of going to meth) and see if that will keep me from being knock limited in 3rd and 4th in the quarter.. Dyno would work, but I have never had to resort to paying to tune so far... Appreciate your input on springs and P rods. Thoughts on trunnion upgrade? Thanks for all of your input these past few months!!
Yeah, 4th WOT is 156mph at 6.8k with the c5z trans lol.
Youre, in MN. Just go full E85. Holiday is the most consitant in terms of E percentage. I never have to adjust the tune if I stay with Holiday Ethanol.
Call up Shardon Performance in Hugo. They will rent their dyno and you can do your own tuning. I got 10 pulls in under an hour. Really nice guys and rates. Ill be going there this spring if I can swing a new engine from TRES this winter.
#88
St. Jude Donor '21
I like tuning at Rock Falls on a test day. $70 and I can let the car cool between runs and tweak the tune making a nice day out of it. More real world for the car too.
What is TRES?
Sounds like you live in MN too. We should get together and make a trip to Rock Falls in the spring?
#89
The Race Engine Shop. Mike knows his **** and a great dude on top of it. MVP@TheRaceEngineShop is his screen name
That would be fun. Im hoping to go alot next spring and summer. I could only manage 11.2 @136 mph.I couldnt hook in 1st or second at all. Looking forward to trying out the new Viking coil overs.
#90
#91
the difference at most will be about 2psi more for the 3.6 compared to the 3.8 and if it's too much you can set the shift points sooner or install a restrictor plate to regulate peak boost... once you get a taste of it I wouldn't be surprised if you wanted to go down in size from the 3.8 anyway
#92
Received 1,260 Likes
no they don't but you can easily make one... personally I don't think you need them and I'm not really a fan of them but they do allow you to run a smaller pulley to gain more in the midrange since you are spinning the blower harder and limit peak boost on the top end
#93
St. Jude Donor '21
Neutron - usually you are pretty vocal but you steered clear of the question about the 1999 rod bolts. Do you have an opinion on that matter? Curious what you think...
#94
Guys, what's your take on speed density? I read different things. Some articles say a SC with 10psi is when you want to start using speed density, others say up to 15 psi before the stock maf is out of range. What are your experiences? I believe if J do end up err on the side of caution I may go 7-9 psi and possible keep the Maf. Andy from A&A has not responded to me yet. I will speak to my tuner to ight as well to see what he can do..
#95
The LS1 PCM has a hard limit of 512 grams/second of MAF air flow, which is ~ 67 lb/min or air ~ 670 bhp. It's not strictly related to boost pressure.
I've read about guys scaling a bunch of other tune tables to get around this limit and keep the MAF in place. Much more common is to ditch the MAF when you get into the 500-600+ hp range and just go speed density. A good speed density tune should be fine and have very minimal downsides.
One downside to speed density in my experience is any sort of airflow mod, you would want to re-tune the fuel/VE tables... a MAF is much more flexible in this regard.
MAF vs SD for me would come down to what your power goals are.
#97
are you saying that the 3.6 gives you more midrange then the 3.8? Then perhaps this is the way to go since I want to keep my shift rpms to a max of 6000 or 6100.....Do I have this right? My next question would be how much can the stock a4 with a 3200 stall handle? Now I do not plan on racing much at all, if any and not on drag radials since I dont own drag radials. The car is a weekend toy..thoughts?
#98
, hopefully someone will chime in on that
#99
#100
I like speed density, my car has been tuned that way since my blower went on and it runs great... you just really need a good knowledgeable tuner to get it done right... most go to speed density when their power exceeds the maf scale, you also eliminate the risk of breaking the housing apart when you remove the maf haha... a&a actually makes a billet maf housing to prevent that also... from what I understand the maf is more accurate though, maybe an ls3/7 card maf would work better than the stock c5 maf but I don't know the power capabilities of those and what it would take tuning wise to change over to one of those... if you ever plan on spraying meth and keep the maf that is something to think about as well because of the nozzle placement in regard to the maf
