My 98 Vette
#101
Worked on more stereo wiring this weekend. Installed the HDMI/USB plug for android auto and cut the hole for the hard drive cable in the console. Got the radio wired up. I still need to move the pink wire in the factory harness for the 5v antenna module lead to match up another wire I'm going to use on the harness adapter. I also have a 12v to 5v convertor that I'll be using to get the 5v power to the antenna module. Got all of the other wiring completed, but found out the left front amp output does not work so I need to exchange that amp. Everything else works great. Tested the back up camera so I can mount that soon. I ordered an antenna coax extension since the factory one is so short. Once I have that I can get the head unit mounted. Here are a few progress pictures.
#103
Got the rest of the wiring done for the head unit. Just waiting for the replacement amp to get here. So got one door panel on. I had to repair a tab on the passenger door panel. I had forgotten to post a picture after I had changed out to blue LEDS in the interior. I'll have to post some more of those when I get the car back together.
#106
Getting there! Just need to make some more minor adjustments to fit the head unit just right and waiting on he sub box that is on order and being built.
#113
Thank you very much! Little slow right now. I've been waiting for my sub box to get here. The first one was made for a single sub when I ordered it for a dual. Should have that this week though. The radio brackets that came with the double din bezel from Vettenuts broke. Second pair of these I got from them that broke. So I am looking into getting some metal ones or making my own. Got my new license plates in yesterday for my 80 Camaro and the Vette which let me put the plate surround on and the back up black outs on finally. You can also see where I mounted the back up camera above the license plate. I had some custom decals made that I colored and designed to replace the Bose emblem with a Polk Audio emblem to go with the Polk speakers I am using. They didn't make them quite right, you can see where the A and U are not straight. I will probably have some better ones made in the future, but these will work for now.
#114
Received the subwoofer box and cover the other day for my 10" JL Audio subwoofers. I put in some carpet pieces to cover up the grey cargo inserts. Also made up some radio brackets based on the Vette Nuts brackets I glued back together for a template after they broke. They don't look pretty, but should do the job.
Heyspike (04-14-2019)
#116
Also, are you using CarPlay with that deck? I lost nearly all of my bass when I swapped from an older Kenwood to that unit. I've played with every setting imaginable and cannot get anything out of it.
#118
Thank you. No muffle, I'm using the subs on a one channel mono amp so they are bass only. I am using Android Auto with my Pioneer head unit. I have no problems with getting bass. There is an option in the settings of the head unit for turning the subwoofer on and off and you can change its phase. It's default is off.
#119
