aftermarket tire pressure sensors
After now having 3 flat tires (2 on the corvette) in the last 2 months I curious if any of you guys knew of a good set of tire pressure sensors that possible are bluetooth that I can hook up easily and into my phone? Since I have a Z06 I dont have the sensors stock in the car, and just figure it might be nice to be able to see or get an alert they are going down. Instead of walking out to the car and seeing a tires flat and having to figure something out quickly.
Any input would be great
Hadn’t seen that one. The one I’m leaning towards is the nanda zus. It’s a bit more expensive but looks like a good unit.
Received 19,220 Likes
'20-'21-'22-'23-'24
Interesting - if you go that route, please post up your results.
After some research I probably spent way to much money on it. I went with the fobo system. Seems good and has pretty good reviews. Guess we will see and I’ll let you know.
If that system doesn't work out, you can add TPMS to your Z06. The RPO exists in the car's computer. You need to have it turned on and add sensors to your tires.
