without grinding down studs, what is the smallest hub centric wheel spacer for c5?
I want spacers for my c5, I just don't want the biggest. the smallest without grinding studs
Spacers usually require longer studs, at a 1/4" your probably fine. Don't see why you would want to grind?
Received 1,261 Likes
I think he is referring to spacers that use the oem studs to hold the spacer on and the spacers have their own studs that hold the wheel on... if the spacers aren't deep enough then the oem studs will stick out hence why they would need to be ground flush with the spacer
he might have meant 1 and 1/4", in that case he would need the adapter style... if he only needs 1/4" then I agree to just get a normal spacer, the lip on the hub is large enough to accomodate that size spacer and still have enough to center the wheel
oh no, I don't want to grind! lol I only wanted my rear wheels, somewhere around 3/4 of an inch out, But that would of required grinding the studs down with that thin of a spacer, and I like knowing I can take them off and not need to do anything, if I wanted. So I ordered the 1 1/4 inch. The c6 wheels on the c5 look killer, but they do sit tight in there! I'll have an aggressive look with the spacers, especially since im running a 305/35 19r Nitto 5r
