Make the switch to LED's or not?
Hi guys-so, i'm changing out my front DLR/Turn signal lenses to a smoked lens set. Contemplating switching those over to led's with hyper flash harness and switchback LED's. Here is my question-seems like the main reason for the switch is the heat from the stock bulbs throw off some heat, eventually frying the seals/lenses, and letting water in and then you start blowing bulbs. either that or some folks want brighter lights/different blink sequence. Ours is not a daily driver-only sees good weather (which here in PNW is about 3 or 4 months in the summer!). So we are talking about maybe 4K miles per year. Im not real particular about the brightness of the DLR's or the blinkers, or what pattern, but should i be concerned about the heat issue? Car has 45K on it now and i don't seem to have any seal/lens issues (other than they look old) with the stock set up. I'm just a teacher and don't have money burning a hole in my pocket-the lenses were something we wanted to do because they are going to definitely look better. I only want to go the LED's if its justified for my particular circumstance. I can totally see it if i lived in arizona or so cal where we would be putting more miles on and out a ton at night, or if it were a DD, but not the case for us...thanks in advance for any advice
jp
jp
Going to LEDs is worth it for the heat issue alone. Switchbacks are used because people like white running lights and DRLs. You can get 3157 amber only LED bulbs that have two different brightness levels, just like the regular incandescent bulbs. Choose whichever tickles your fancy, but a hyperflash harness is a must.
You don't have to go quite this nuts.... but there are lots of options from this forum vendor: https://radioflyerinnovations.com/sh...pgrade-package
I bought the whole thing- new black/clear lenses, switchback harness, led strip mod, etc. I still haven't got around to installing all of it though so I can't give any feedback on the install yet.
I bought based on many good comments from many forum members on this vendor.
Using LEDs for things that "stay on all the time" is OK - when you start using them for "things that flash" that can get tricky - there are "hyperflash harnesses and resistors" available - but I've read many stories here of struggles.
Using LEDs for headlights is getting controversial with the complaints of people being blinded by oncoming cars. With the vette being so low this typically isn't a problem. I'm going to an HID projector setup for the low beams and LED for the highs.
I also have a 4runner and on that forum lots of talk about LED light bars and all the rest. I think these things are a fad that will pass - in this application they "throw light everyplace" and also can't melt snow and ice. On my new bumper I'm skipping the LED light bar and going with (focused) PIAA fog lamps.
Good Luck!
Good Luck!
The housing will melt from the inside out, so you would need to pull the bulbs & check, my car is a 2003 just under 10,000 miles, pictured is my passenger side housing inside above where the bulb snaps in at that mileage. My driver side is perfect, so you may or may not have any problems as mine was only the one side, I now run Radioflyer DRL's in std amber.
Received 19,233 Likes
'20-'21-'22-'23-'24
Yes, the stock bulbs do put off a lot of heat and over time will melt the plastic of the housing and allow water intrusion. I had to replace the housing on the ‘03 I had for this reason. The LEDs will solve that problem, but only you can determine whether the change is cost justified. I ended up just replacing the housing and leaving in the OEM bulb, but I seriously thought about changing to LEDs (already had the hyper flash harness). Sold the car before I made any changes.
I had to replace the housings on my 2004 DD at about 40K miles They were melted through at the tops. I experimented with LEDs, switchbacks and non switchbacks. I was not satisfied withe the brightness or the look. I went back to the OEM incandescent bulbs. 117k miles now and no problems. Lens are looking a little yellowed. May replace the housings again. Maybe next year.
I installed clear lenses and LEDs/switchbacks along with the hyper flash harness after I discovered the original lenses had burn holes. It’s a pretty straightforward install and I like the look and reliability.
Thanks for all the opinions guys-totally aware of what needs to be done as far as the harness and bulbs. That is an easy change for sure. Sounds like its kind of a hit or miss as to how much/how bad your lenses get fried. Think what i'll do is remove the lenses and check out the meltage...if its bad, i'll make the switch. I gotta be careful because sometimes i tend to buy stuff just to give me something cool to do on the car! (guess thats my weekness )
Besides, LED light bars are a much more elegant way of doing DRLs than using the turn signals or dimmed headlights. More than a few countries require DRLs.
Thanks for all advice guys-decided to bite the bullet and go LED's. Guys at Corvette Envy made the deal too good to pass up, so will do this once and be good to go and not have to worry about molten plastic in the future
jp
jp
Received 1,679 Likes
I have the RadioFlyer switchbacks and couldn’t be happier. The white LED DRLs definitely update the look of the car but still have the amber turn signals. I get compliments all the time from fellow C5 owners.
OH FUDGE! did i mess something up here? i ordered the smoked depot drl lenses that upon closer inspection appears to be clear (ie not amber side marker lenses). So, does that mean i need to put an amber 194 led in there for the side marker led's to be legal? I know my switchbacks will be amber until i turn the lights on, then will turn white. i'm talking about the side markers that take the 194 bulbs. Don't want to get pulled over for something as stupid as the color of a light!
Night Owl for life
Received 3,241 Likes
I would use an Amber 194, they’ll still show through the smoke lens when lit.
