2000 Sport Seat Wiring Diagram
Received 5,554 Likes
Tourist from the C2 forum here. I have C5 (2000 MY) sport seats in my ‘64 coupe.
Does anyone have the wiring diagram for the two connectors on the bottom of the seats? Extra credit if you have a source for the connectors so I can make a more factory installation. Thanks in advance and here’s a picture:
Seems the blue connector may be for telescoping column only and not used in my application, so that leaves the black connector which is the only one on the passenger seat. Although the passenger seat has less pins (lack of lumbar support possibly?).
2021 C5 of the Year Finalist - Unmodified
I am looking for the same information to be able to power the seat on the work bench. did you find the wiring? it looks like there is several 12v and several ground .... but I am not fully sure.
if you found out, I would appreciate the info.
TCFS
TCFS
TCFS (03-26-2019)
The following 3 users liked this post by SG Lou:
Thanks!
I could not find how to make the seat control to work with the 12V supply. I went to the car and plugged it back, moved it....and then took it out to film the issue.
TCFS
TCFS
SG Lou (03-27-2019)
Great info!
i did find the car harness plug at salvage, but they wanted $80 because they had to cut the harness. I bought two new matching connectors from Summit for a few bucks and will replace the factory connector. The wiring diagram is really helpful, thank you!
SG Lou (03-27-2019)
I used this guy when I installed C6 seats into my C5. http://www.vetteworksonline.net/cata...x.php?cPath=77 He made me a harness and plugs so I could use my stock plug to control my seats.
