C5 Custom Wheel & Tire Database: please fill in your info
NCM Lifetime Member
Received 3,929 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
Wheel Make: CCW
Wheel Model: SP 510
Front Wheel Size: 19 x 10 with 2" lip
Front Offset or Backspace: +57 offset 7.75 backspace
Rear Wheel Size: 19 x 13 with 3" lip
Rear Offset or Backspace: +48 offset 8.875 backspace
Front Tire Size: 275/35/19 Nitto Invo
Rear Tire Size: 345/30/19 Nitto Invo
Suspension mods: Lowered on LG Motorsports drop spindles and coilovers.
Problems or Issues, such as clearance/rubbing problems: Had to remove rear brake ducts to run the 345 rears. No problems after I got the shock rebound and height adjusted.
Misc. comments: Brakes are Wilwood Forged Narrow Superlite 6 piston front/4 piston rear with 14” rotors front and rear. Also using Customadeonly billet
Wheel Spacers - 5X4.75 (5X120.7) 70.3CB - 5mm on all 4 wheels. Rear fenders are TPE T2's.
Wheel Model: SP 510
The following 9 users liked this post by lewislgZ06:
dreamr616 (04-19-2019),
FYRARMS (04-15-2019),
jd_black_00 (05-05-2019),
JustMyMagination (12-18-2019),
Michael Zolla (03-10-2020),
and 4 others liked this post.
Wheel Make: Forgestar
Wheel Model: f14 black
Front Wheel Size: 19x9
Front Offset or Backspace: +44
Rear Wheel Size: 19x12
Rear Offset or Backspace: +23
Front Tire Size: 255 35 19 invo
Rear Tire Size: 345 30 19 nt05r
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: lowered on stock bolts
Problems or Issues, such as clearance/rubbing problems: Needed 3mm spacer to clear c6z brakes in the front should have ordered a different offset.
Misc.Comments: Running tpe 2" wide fenders
The following 9 users liked this post by tommypenguin:
Brummm (02-18-2021),
Imnotsure40 (06-19-2021),
lewislgZ06 (04-21-2019),
mstromquist (10-28-2019),
NemesisC5 (08-06-2020),
Wheel Make: ForgeStar
Wheel Model: CF10
Front Wheel Size: 19 X 9
Front Offset or Backspace: Listed as C5 Flush-Fit
Rear Wheel Size: 20 X 11
Rear Offset or Backspace: Listed as C5 Flush-Fit
Front Tire Size: 275/30/19
Rear Tire Size: 305/25/20
Suspension mods:Lowered .75" on stock bolts
Problems or Issues, such as clearance/rubbing problems: None
Misc.Comments:
Wheel Model: CF10
Misc.Comments:
The following 5 users liked this post by WayneCar:
oh1c5Pewter (07-03-2020),
Ren10 (12-10-2023),
Stokes1 (05-03-2019),
USAZR1 (04-14-2019)
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
A C5 Custom Wheel & Tire Database has been needed on this site, since these cars were built. If your C5 has a custom wheel and tire combination, please add their specs into this database. Feel free to Copy & Paste the information parameters, in this first post. This is a database, not a question & answer forum. Please ask your questions in the forum below, not this thread.
NOTICE: If your C5 has the original equipment wheels, it is preferred you do not post in this database, for obvious reasons. Thanks
Wheel Model: CF5
Front Wheel Size: 18x8.5
Front Offset or Backspace: +40
Rear Wheel Size: 19x10.5
Rear Offset or Backspace: +55
Front Tire Size: 235/40/R18
Rear Tire Size: 275/35/R19
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: C5 Z06 Springs w/Bilstein Sport Shocks, Aftermarket Rear Lowering Bolts, No front bolts
Problems or Issues, such as clearance/rubbing problems: Spring-on-Control Arm contact makes a creaking noise at low speed when turning
Misc.Comments:
Wheel Model: CF5
Misc.Comments:
The following 4 users liked this post by jd_black_00:
Wheel Make: CCW / Weld
Wheel Model: SP018
Front Offset or Backspace: (exact unknown)
Rear Wheel Size: 19
Rear Offset or Backspace: (exact unknown)
Front Tire Size: 275/35/18
Rear Tire Size: 305/30/19
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: Lowered on bolts
Problems or Issues, such as clearance/rubbing problems: 3mm spacers all around. Backspacing unknown. Rear brake ducts were removed a long time ago. Zero rubbing.
Misc.Comments: Will measure backspacing. Fits C6Z51 brakes. Tires (Potenza S04) run narrow for their size. Plenty of room to lower it a bit more.
Wheel Model: SP018
Rear Wheel Size: 19
USAZR1 (04-15-2019)
Wheel Make: Flow One
Wheel Model: F4
Front Wheel Size: 18 x 9.5
Front Offset or Backspace: +50
Rear Wheel Size: 19 x 10.5
Rear Offset or Backspace: +54
Suspension mods: Lowered on factory bolts
Problems or Issues, such as clearance/rubbing problems: Axle stubs had to be ground down to install center caps. Supposedly Tire Rack has fixed this issue.
I don’t have any good pics. Sorry. I’ll work on that
heres what it looked like before I lowered it
Wheel Model: F4
The following 8 users liked this post by Dark Sarcasm:
DECON BLUE (07-14-2020),
OneBadBanana (01-21-2021),
and 3 others liked this post.
Wheel Make: BC Forged
Wheel Model: HB05
Front Wheel Size: 19x10
Front Offset or Backspace: +55
Rear Wheel Size: 19x11
Rear Offset or Backspace: +60
Rear Tire Size: 325/30/19
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: LG2 coilovers lowered
Problems or Issues, such as clearance/rubbing problems: rear tires are too tall at 27.4", they hit the front top of the fender liner over dips when lowered too much. I have since raised it to 1" fender gap and it just skims occasionally.
Update: I have 1” flared fenders from Vette Nuts and 325/30/19's which have 26.7" diameter, essentially the same as stock.
Recommended Tire size for optimal clearance: 275/30/19 and 305/30/19. These will fit perfectly without any body mods.
305/35/19
325/30/19
Wheel Model: HB05
305/35/19
325/30/19
The following 8 users liked this post by workmanw:
Michael Zolla (02-28-2020),
Wheel Make: BBS
Wheel Model: LeMans 2 pc alloy
Front Wheel Size: 17 x 9 Mfg# 9JX17H2ET52
Front Offset or Backspace: +52
Rear Wheel Size: 18 x 10 Mfg# 10JX18H2ET54
Front Tire Size: 245/45ZR17 Nitto NT555 G2
Rear Tire Size: 275/40ZR18 Nitto NT555 G2
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilers: Z51 rear sway bar
Misc Comments: BBS LeMans wheels were one of the earliest high end ($3200 set) after market wheels made for the C5, mfg to base OEM specs. Limited production and total sales of approx 220 sets. Mfg part numbers are stamped into front of wheels.
The following 2 users liked this post by NHrdking:
USAZR1 (04-20-2019)
Wheel Make: CCW
Wheel Model: T-10
Rear Wheel Size: 20 x 11
Front Tire Size: 285-30-19 Pirelli P-Zero
Rear Tire Size: 325-25-20 Pirelli P-Zero
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: Lowered on stock bolts
Misc.Comments: Yes....It's a true Z06
Wheel Model: T-10
Wheel Make: I-Forged
Wheel Model: TE14S
Front Offset or Backspace: can't remember
Rear Wheel Size: 19 x 11
Rear Offset or Backspace: can't remember
Front Tire Size: 265-35-18 Hankook Ventus
Rear Tire Size: 305-30-19 Hankook Ventus
Wheel Model: TE14S
The following 4 users liked this post by jerkyboy:
Wheel Make: iForged
Wheel Model: Concave Series (Milano's)
Front Wheel Size: 19 x 9.5
Front Offset or Backspace: N/A
Rear Wheel Size: 20 x 10.5
Rear Offset or Backspace: N/A
Front Tire Size: 265-30-19 Nitto Invo's
Rear Tire Size: 305-25-20 Nitto Invo's
Suspension mods: LG C5 GT2 Adjustable Coilovers
Problems or Issues, such as clearance/rubbing problems: N/A
The following 11 users liked this post by Joe_Joe:
c Mac daddy (06-30-2023),
DECON BLUE (08-14-2020),
dreamr616 (05-15-2019),
FYRARMS (05-15-2019),
Johnson 92 (05-22-2019),
and 6 others liked this post.
Wheel Make:Forgestar
Wheel Model:CF5
Front Wheel Size:18x9.5
Front Offset or Backspace:+50
Rear Wheel Size:19x11
Rear Offset or Backspace:+55
Front Tire Size:275/35
Rear Tire Size:305/30
Problems or Issues, such as clearance/rubbing problems: no issues so far
Misc.Comments:
Quote
#33
Wheel Make: HRE
Wheel Model: 893R
Front Wheel Size: 10.5x19
Front Offset or Backspace: 8.75" Backspace
Rear Wheel Size: 12.5x20
Rear Offset or Backspace: 9.75" Backspace
Front Tire Size: 285/30ZR19 ZP Michelin Super Sport
Rear Tire Size: 335/25ZR20 ZP Michelin Super Sport
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coil overs: Lingenfelter Rear Wheel Well Tub Kit - L.G. Motorsports Billet Lowering Knuckles - L.G. Motorsports Bilstern Coil Overs - Pfadt Stabilizer Bars
Problems or Issues, such as clearance/rubbing problems: During the full turn of the steering wheel the tires will rub on the brake cooling ducts.
Misc.Comments:
The following 3 users liked this post by Pumba:
#34
Wheel Model: CF5V
Front Offset or Backspace: +30
Rear Offset or Backspace: +25
Front Tire Size: 295/30/19 (Michelin Pilot Super Sport)
Rear Tire Size: 345/30/19 (Michelin Pilot Super Sport)
Suspension mods: Lowered, LG G2 coilovers and LG swaybars
Misc.Comments: Front fenders are from Corvette Creationz. Rear fenders are from L5 Motorsports.
Wheel Model: CF5V
The following 4 users liked this post by MAJ_Charlie:
#35
Wheel Make: OE Wheels
Wheel Model: C5 Deep Dish
Front Wheel Size: 17x9.5"
Front Offset or Backspace: +54
Rear Wheel Size: 18x10.5"
Rear Offset or Backspace: +56
Front Tire Size: 275/40/17 (Toyo Proxes R888)
Rear Tire Size: 305/35/18 (Toyo Proxes R888)
Suspension mods: C6 Z06 Shocks, Sway Bars, End Links.
Halffast (05-12-2020)
#36
Location: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Wheel Make: CCW
Wheel Model: 505A
Front Wheel Size: 18x9.5
Front Offset or Backspace: unknown at the moment but, I have it written down at home
Rear Wheel Size: 19x13
Rear Offset or Backspace: unknown at the moment, but, I have it written down at home
Front Tire Size: 275/35/18 Michelin Pilot SS
Rear Tire Size: 345/30/19 Michelin Pilot SS
Suspension mods: C6 Z06 shocks and sways, Breathless performance lowering kit, Steinjager end links, Baer bump-steer kit
Problems or Issues, such as clearance/rubbing problems: The Z06 brake ducts were functional, however after going with such a wide patch of tire, the ducting was removed. No issues of clearing or rubbing problems.
Misc.Comments: Adding a chin spoiler, to an already lowered vehicle, makes negotiating obstacles a bit more "sporty"
Aug 31,2013 St.Charles 006 (800x600)
My 2000 Corvette in front of Vettes Bar& Grill, Saint Peters, MO.
Wheel Model: 505A
The following 6 users liked this post by C5R USA:
EAUXNO (12-13-2023),
Not4spd (06-27-2019),
USAZR1 (06-27-2019),
and 1 others liked this post.
#37
Wheel Make: Ace Alloy
Wheel Model: Slicks
Front Wheel Size: 18X9.5
Front Offset or Backspace: 53mm
Rear Wheel Size: 18X11
Rear Offset or Backspace: 53mm
Front Tire Size: 285/35/18 NITTO 555 G2
Rear Tire Size: 305/35/18 NITTO 555R
Suspension mods: Stock ride height, C6Z shocks, Johnny O' Connell swaybars, adjustable metal endlinks
Misc.Comments: Wheels are designed to clear C6Z brakes
With C6Z brakes installed:
Wheel Model: Slicks
The following 10 users liked this post by Not4spd:
04C5Lemans (05-02-2020),
dreamr616 (07-04-2019),
jjc508520 (08-22-2019),
LouWinget (07-17-2020),
Mediocre_Mike (04-28-2021),
and 5 others liked this post.
#38
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
2000 c5
Wheel Make: GM
Wheel Model: C6 Corvette OEM Grand Sport
Front Wheel Size: 18X 9.5
Front Offset or Backspace: +40mm/ 6.35”
Rear Wheel Size: 19X12
Rear Offset or Backspace: +59mm/ 8.3”
Front Tire Size: 275/35ZR-18
Rear Tire Size: 325/30ZR-19
Suspension mods: Lowered on LG Drop Spindles and Stance Coil Overs, C6Z front and rear brakes, C6Z sway bars
Problems or Issues, such as clearance/rubbing problems: None to date.
Misc.Comments:
Misc.Comments:
The following 3 users liked this post by alxltd1:
#39
Cruise-In IX Veteran
Wheel Make: CCW
Wheel Model: SP16A
Front Offset or Backspace: ?
Rear Offset or Backspace: ?
Front Tire Size: 275/30-19
Rear Tire Size: 305/30-20
Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: lowered stock bolts
Problems or Issues, such as clearance/rubbing problems: none
USAZR1 (07-30-2019)
#40
Wheel Model: F14
Rear Wheel Size: 18 x 10.5
Rear Tire Size: 315/35/18
Suspension mods: Lowered on stock bolts
Wheel Model: F14
The following 8 users liked this post by INSTIG8R:
Chuck Varela (03-06-2021),
Iceman60467 (08-25-2021),
