Gentex rearview mirror retrofit
With all of the posts I could find on the topic, there still seems to be some misinformation, or a lack of information, out there for retrofitting a Gentex mirror in place of the standard, flip-up mirror so I figured I'd post some info anybody doing research in the future 👍 I bought a Gentex 453 (newer models with sealed light sensors and beefier mount. This specific model has auto dimming/ Homelink/ hidden compass, no map lights) from eBay for about $60 and just easily swapped it in without much fuss. Stock harness has 4 wires (2 orange, 1 brown, 1 black). Gentex also has 4 wires, but 2 were labeled 12v+, 1 was ground, and 1 was optional reverse 12v+. I originally wired it with the 2 stock orange wires connected to the 2- 12v+ Gentex wires, stock black to Gentex black (ground), and left the other two wires (stock brown and optional gentex/) disconnected entirely. I tested the mirror and it came on/turned off with the footwell lights. Perfect, I thought. Buttoned it up, took it for a drive, closed the garage door just fine, but then quickly realized the auto dimming and compass weren't on aka there was no power to the mirror. Yet when I got back home, the Homelink button still opened the garage just fine. So it's apparent the Homelink was connected to constant 12v, but the compass and auto dimming were on a separate circuit and it just happened to be the one that turned on...and OFF...with the footwell lights. All research told me that the brown wire (which I had left disconnected) was only hot with the headlights on. Until I found one guy among tons of others that had a conflicting statement: brown was hot with acc, not headlights. I switched the auto dimming/ compass wire over to the stock brown wire and bingo: a correctly functioning mirror. The mirror now gets full power with the key turned on and has Homelink with or without a key in the ignition. With all of the research I did, none of this was clearly spelled out, nor was a relevant Gentex model number, so I figured I'd share. This is on a 2001 with a standard mirror 👍👍
bigsapper (03-11-2019)
Night Owl for life
Received 3,246 Likes
Good job on the new mirror. I put one in w/map lights many years ago myself
Night Owl for life
^if you want to still have map lights that is one thing to certainly look out for
Received 3,866 Likes
2015 C5 of the Year Winner
Thanks for all that info. If I get one I'll keep this thread so I can figure it out.
Absolutely!
Just to be clear for all interested, you will have to splice your factory wires into the harness wires that comes with the mirror (hint hint, make sure your new mirror includes the piggyback/harness). I've never had a problem doing that, but I know some people aren't comfortable with wiring or don't want to touch their factory harness/wiring. I believe there used to be vendors that would sell you a plug-n-play harness, but I don't know if any of those are around anymore. I don't plan on removing it from my car again, but I left enough wire on the stock piggyback to wire it back on if necessary. Simple matter of stripping a few wires, using crimp connectors (or solder if you're fancy), and wrapping them back up with electrical tape.
JimHarris4 (10-15-2019)
heggsc5 thanks for your response. I respect anyone like yourself that courageously takes projects on with little direction and is able to make them work.
I too, really only want the homelink, don't care about a compass or temps, but I do like the extra lumens the map lights give off. I have the auto dimming mirror in my Challenger, but it doesn't seem to dim the mirror fast enough for my sensitive eyes.... Seems like most of the mirrors for sale have those other features. I like your idea about adding a strip of LED lights on one without map lights, however, not sure I would know what's involved with doing that.
You mentioned a pig tail connection, I see many of the mirrors have what appears to be some sort of wiring connection or pig tail attached to them. Is that what your are referring to?
I get what your saying about the vendors selling these, they definitely run the gamut. Since you were happy with the one you purchased, would you share the site where you purchased it?
The wire I have still available is JUST for courtesy lights. So the lights I would install with that wire would only come on, and subsequently turn off, with the approach lights and footwell lights. It wouldn't work if I wanted to turn them on manually while I was already in the car. If I need a light while I'm in the car, I can easily use my cell phone light (which is far more usable than fixed map lights anyway lol)
Yup, that's exactly what I'm referring to. At the end of those wires is a harness/plug that plugs into the port on the mirror. Without that plug, and enough wires to splice on it, you won't be able to wire the mirror.
Sure thing, the seller I got mine from was "mirrors_n_more"
Which Gentex would you recommend which includes auto dimming, back up camera option and map lights? Dont need homelink. The Gentex home page refers to Voxx and Mito as an authorized seller but none of the current Gentex units show map lights in their description. Thanks
Thanks heggsc5, perhaps another member can make a recommendation for an auto dim mirror with back-up camera and map lights. I hope that you don't mind my putting this question on your thread. thanks again.
heggsc5 (03-26-2019)
I believe the later MY plugs were different and more difficult. Mine just unplugged easily. I recall seeing many threads about the difficulty some had with the later OEM plug, I don't believe it's difficult once you understand how it works. Worth a quick Google search
