strange tire wear on rear tire
Hey guys been a long time since I posted. Been very busy. Anyway I got this 99 coupe yesterday and it has a set of Michelin A/S on it and the rear passenger tire I noticed was worn on the outside. The more I looked the inside was showing the cord. Now the car has 90k miles and is an M6. I was going to buy to drive through the summer as I like to have a car I don't mind to get a scuff on here or there, or drive in the rain, but I bought a 98 convertible that will fit the bill I just wish the convertible was a M6 like this 99. Anyway. I called the Chevy dealer and had them order me a nitto tire and will do an alignment after that. I just wanted your thoughts. More than the tire, the car keeps coming up with the service abs, stability, and something else. The two lights illuminated are the car skid mark, and the abs. I have been getting 1233 code. Please not I am not a good mechanic. But I want to sell this car to someone and do not want to sell them a huge problem although I think even with the lights on the car is worth 10 grand. Anyway calling all guru's ….
Zen Vet Master Level VII
Cord showing is a sign of imminent seperation- you have a safety issue here.
What is the date code on the tires? The tread looks good, but if the tires are old, they can (and will) separate.
cody123 (03-21-2019)
bill where would the dates be? also any idea on the dash lights? I remember my old impala SS had a bad wheel bearing and it had a abs and trac light on, are these cars the same?
Take the fender off to prevent damage do them, do copious burnouts
Then get new tires and an alignment
I would also check the Rear Tie Rods.. INNER & OUTTER . They do wear out, just like the fronts and will
cause a rear alignment issue. That's usually why tires would wear on inside/outside.
To my knowledge, only GM makes the outters. So be prepared to order them ahead of time for your alignment shop
Banned Scam/Spammer
Received 1,319 Likes
I agree 100% change the inner/outers on both sides and have it aligned with new tires.
I strongly suggest that you do NOT replace just one tire. The posi unit in the differential may not be happy with two tires that aren't very close to the same OD. Believe me, I know this from personal experience....
The date of the tire is located on the sidewall, typically four numbers that are circled by a rectangular oval. While the code varies from manufacturer to manufacturer the set of numbers typically note the week the tire was built and the year, so a code that reads "2316" would be the twenty-third month of 2016.
Tires should be replaced every five to six years regardless of tread life, so if they are that old or older there is a high chance of abnormal wear or failure.
I also agree that you need to have the car's alignment and suspension components checked. A car that appears to be driving straight does not necessarily mean it has proper alignment.
the thing is with this car the codes aren't that intermittent they always come on, they aren't on as soon as you start it but very quickly they turn on. Also, as far as replacing both tires, surely a new Michelin and a new nitto wouldn't mess anything up. I know on any vehicle you don't want to run two different size tires, but these are the same size , and the Michelin is almost new and the nitto will be new. I will drop the car off at chevy today
also good advice about the tie rods I didn't realize the rear had tie rods, but it makes me wonder why it would only wear the one side...
the car runs and drives excellent, I am going to have it serviced while in the shop. It has a clean Carfax 2 owners. I think 10k is super cheap for this car. From what I've seen people ask insane prices for these cars. I've had probably 10 of them myself lol. I love them I think I like a nice c5 better than a C6 unless its an ls3 C6
Simply the tires WILL fight against each other even if the same size. You are having codes related to traction control? Well, different tires (fighting each other) may be part of your problem?
Received 3,812 Likes
St. Jude Donor '03-'04
This looks like a suspension geometry problem. A C5 requires a 4 wheel alignment… the rears have to be done before the fronts. Looks like that corner took a hit with a pothole or some road hazard.. before replacing any tires make sure you have a good 4 wheel alignment,,, do the research, Some one who has a good reputation in alignments. Not every alignment shop does a good job. Many subscribe to the notion that once it leaves their shop, any road hazard could compromise their alignment. You want to get a printed readout, with specs for your car and their final adjustment both fronts and rears.
Bill aka ET
I know a few things because I have seen a few things
Bill aka ET
This is true. After a few false starts, I took mine to the Chevy dealer. The dealer got it spot on, first time. To me this makes sense as the alignment shop "pros" probably just finished with a Camry just before starting on the Vette.
Received 1,679 Likes
This might seem like a stupid question, but I'll ask it anyway. Could that wear be from many miles on an old under-inflated tire?
As much as I am reluctant to take my cars to the GM dealers after the warranties are up, I will say that my local Chevy dealer has been the only shop that gets a 4 wheel alignment correct on my C5.
