Fix for squeaky seat belt tensioner?
The driver side seat belt tensioner of my AE Vert makes a squeaky noise whenever I make even the slightest movement. Is there a way to lubricate this to fix the issue? (Oil up the 'pulley' or whatever is in there)
pull it out of the car and you can probably spray some silicone spray on it....best to remove it from the car so you don't get it on the belt....and BTW these things are position sensitive so when you remove it you have to hold it just right to allow you to pull the belt out
I may have experienced a squeak similar to the one you describe. With every pull at the belt, even a slight one under moderate braking or movement in the seat, I would hear a squeak. In the case of my car- it wasn't anything that lubrication would fix and it wasn't the tensioner mechanism- rather it was the seat belt keeper swivel. I put two circular Velcro felts on the underside of the keeper and no more squeak. I can't explain exactly how or why it eliminated the squeak- but it did!
PS- I recall I may have shot some lubricant into the swivel- so you should try that too.
Try this and let me know if it works for you-
So- a little bit of lube for the swivel, a little bit of lube for the spring cover hinge and some Velcro pads on the swivel and on the lid where the swivel can contact it. That's what worked for me-
