HVAC Light Question
HVAC Light Question
I just replaced the 14 bulbs in the HVAC dual climate control. I have noticed however that the yellow light in the a/c button does not light up, nor does the yellow light in the rear defrost button.
The other yellow lights in the buttons do light when pressed. I guess that it is possible that these 2 lights have burned out.
Has anyone replaced these? What part/bulb needs to ordered and from where?
Thank you,
Ron
Thank you,
Ron
Received 1,679 Likes
When I did the LED light mod to my HVAC, I replaced the A/C on light with an LED as well - so I know LEDs will work for those lights as well.
I took apart Neo Wedge LEDS (scrapped the housing and used the LED) because they already have resistors built in.
Thank you. Has anyone found / replaced with any non-LED replacements?
I replaced the other 14 bulbs with regular filament bulbs.
Send a PM to Gary (SilverC54me) he's a wizard at this stuff - https://www.corvetteforum.com/forums...lverc54me.html
