Best iPod Carplay for C5 vert?
I'd like to put a new radio in my '03 vert. My CD changer died so I want to use an iPod for music and bluetooth for the phone would be nice. I've looked through several threads and here are some thoughts and questions:
Thanks for any help.
- I want to use my iPhone and iPod. All the music is on the iPod.
- Looks like Apple Carplay would be the best choice. Thoughts on that?
- I ruled out the Double DIN models because the Metra bezel is ugly, the Vette Nuts bezel is too damn expensive and I've read here that DD screens don't work well in verts because of glare and wash-out. Thoughts?
- That leaves single DIN units with retractable touch screens.
- Crutchfield has Jensen and Pioneer units that will fit my car. The angle of tilt is not adjustable on any of them. Crutchfield seems like the best source because of their installation kits and customer support. I'm keeping the stock speakers and antenna.
The following 2 users liked this post by My Vette Life:
JimHarris4 (06-15-2019),
Nabcoinc (05-09-2019)
Thanks UCM. That looks like a good, economical option. Not really Apple Carplay and no CD player so I'm going to keep looking.
Still wondering how 'vert owners are doing with flip-out screens. Do they get totally washed out?
MVL: Not really helpful. I have most of my music library on an iPod. My old iPhone won't hold all that music and I have no desire to buy a new phone. My phone is just for phone calls and, if I'm away from home, email. I don't text. I don't have apps. I usually don't even carry the phone.
Whats your beef with iPods? I’ve got an iPod touch which is basically an iPhone without the phone, it has 128gb storage and didn’t require a contract or that I sell a kidney to buy it.
t1fudd (05-10-2019)
Back to my original question:
Will a single DIN radio with a non-adjustable screen work in a vert or will it be totally washed out and useless?
From my initial post:
I have a double din in a vert and i can see it just fine with the top down. IMO nothing modernizes the interior more. If only someone would make a replacement HVAC controller.
I have the metra bezel and while the texture match isn't perfect it doesn't bother me. I prefer the lack of doors over the cup holder and cubby at the bottom over the stock and vettenuts.
Android auto is awesome for music, maps, phone.
I have a sony head unit that looks and works great. I wanted one with a dial, not all touch.
My cable is hidden in the center console, which is where the phone stays while driving so no exposed wires or phone.
Don't forget an amp and sub in the trunk.
rjwvetttt (06-13-2019)
Thanks for the info on viewing. I don't think I want a double DIN but will take another look. I absolutely don't want an external amp or a sub.
The local audio shop I went to modified my stock bezel and installed the new DD head unit with backup camera, bluetooth, gps and a flash drive port. The tech said they have been modifying C5 bezels for years. It looks great.
I have all my music on a flash drive. I use a flash drive in all my vehicles for music.
I download music to my computer run a volume freeware program that sets the volume on all the downloads the same and then put it on a flash drive.
I listen to nothing but the music my wife and I like. We can go for days and never hear the same song unless we want to.
Good luck!
Good luck!
Good point Grandpa. Maybe I'll check the local guy and see what he can do. I was planning to DIY to save money but it's worth looking into.
Time for a C-5: You really have me reconsidering the DD.
I thought I may have found a good alternative in the Alpine ILX-F259 but it doesn't have a CD player and I want to be able to play CDs.
Thanks 50thz06. Good points.
I'm quite sure my iPod Touch is Carplay compatible.
There are single DINs with Carplay such as the Jensen VX4014 but the pop-out screen does not have an adjustable angle and, as you noted it will block the air vents (not a huge deal).
I will check out Sonic, although my inclination is to go with Crutchfield because of their support before and after sales. And I'll also take Grandpa 1's advice and give the local shop a try.
I did not think I wanted the Metra kit because of things I'd read about fit and finish but you and others have said they are good (maybe they've improved) so I'll try to get over my prejudice. Part of my hesitation was stupid--I have one of those rings that slip over the cup holder lid so you can actually hold a cup and the Metra doesn't have the lid (like I said--stupid reason).
I do plan to replace only the head unit. The OEM Bose amps and speakers are good and car stereo can never be hi-fi so there is no reason to change amps and speakers IMHO.
I didn't quite get your last statement: "With either adapter, you will be adjusting for volume level matching to the OEM Bose amplifiers built into the car." Do you mean a one-time calibration sort of thing or do you mean you have to fiddle with the volume constantly?
Thanks.
-Kent
Thanks.
-Kent
It's a one-time calibration thing, so once you get everything wired, do the adjustments/level matching before you close it all up. Also I'd suggest starting the engine and check for engine noise/whine before final assembly in case you have to reground something or re-adjust levels.
Received 2,680 Likes
2018 C5 of Year Finalist
My C5 DD Kenwood with AppleCar Play works great with no additional glare than that I receive in my C7Z and the OEM screen.
I did a single din Alpine and have USB, Sirius, CD and play alll my music on a flash drive. By the way, I found Best Buy will install it free or for $39 so I bought mine there. But the look does not modernize the interior. I wish I did a DD. And without a sub, you will want more bass. I'm looking at DD options now so I can add a camera.
I went to a semi-local shop and ordered the Pio 2500NEX double-DIN, a Rydeen backup camera, Metra bezel and associated installation parts. It'll all be installed next week. Total cost was higher than I'd hoped for but I just don't want to tear into the 'vette in my driveway again.
I may order some 3.5" coax drivers to replace the door twiddlers and install those. I drive with the top down 90% of the time so won't bother with the rear twiddlers--the folded top blocks them.
Will post pictures when it's done.
Dave in Pa (06-15-2019)
