Tire suggestion?
Tire suggestion?
Hello, 2002 fe3 z51 coupe, I have a question about tires, I have reproduction fake z06 rims with OEM tires 275/40/18 rear, I have a few suspension upgrades like, C6 z51 sway bars, Bilstein B6 HD shocks, someone mentioned that with the OEM 275 width I’m not getting full potential of the suspension upgrades, mods, is this false or correct? I do need two new rear tires, so should I fit some wider tires on, I seen 285 will work, but should I? it should give better grip being wider. Thanks
jumpmanmb87 (05-15-2019)
Received 1,862 Likes
Excellent suggestion. I use that site, almost every day.
OP, need more info from you. OEM Z06 rear wheels are 18x10.5's. Your "repro fake" Z06 rears may be 18x9.5 or 18x10.5 or ? Do you know what width they are because it makes a big difference in tire size recommendations. What size are your front wheels and tires?
If your rears are 9.5 width, I personally wouldn't run anything wider than a 285 tire. If they are 10.5 width, either a 295 or 305 will work fine. Yes, a 315/30/18 will fit a 10.5 width wheel but those tires are really short @ 25.5" tall. Why is that important? Because, to keep your front-rear tire diameter stagger in the range that keeps your active handle/traction control happy, you would need to also run an even shorter diameter front tire.
Former Vendor
Me too !!!
excellent answer/post !!!
Received 3,812 Likes
St. Jude Donor '03-'04
Unfortunately, as our C5's age, tire selection becomes an issue. You dont want to spend money on new wheels ( different sizes ) just so that you can get a specific tire that might be available in a specific size. 20 years after the fact, selecting tires is not a given.. what you have to do in 2019 is find all of the "available" tires, with actual stock in house that you can purchase. From this research you can select the best tire for your specific needs from those that are available. Price, compound etc. Dont compare one manufacturers tread ware number to another manufacturers.. This is not a Universal number. its only for internal comparison within that specific manufacturer.. A higher thread ware rating could be in reality, a lower performer then another manufacturers lower rating.
The following 2 users liked this post by Evil-Twin:
Edmund Iverson (05-31-2019),
Yello95 (05-16-2019)
Received 19,226 Likes
'20-'21-'22-'23-'24
The wheel width should be stamped either on the inside of one of the wheel spikes or on the back side of the wheel on the lip edge. Just look carefully on the back side of the wheel.
Yep. 10.5" wide will fit a 315, and should fit without rubbing assuming the offset is correct and the car is at stock ride height. Both front and rear. (Front will have a fair bit of poke running a square 10.5" setup using the C5Z rear wheel.)
You can fit basically anything from a 265 to a 315... I'd personally recommend at least a 285 on the rear. Fronts are a bit tricky because while you can fit a 315 up front and you can get a super sticky tire, the stock steering pump isn't really designed for super wide / super sticky / super high effort (eg, track, autocross). You can do some but not all of the above.
OP, what do you use the car for? Is this seeing road course? Autocross? Canyon carving? Daily driving?
Up to a 305 size rear tire, they shouldn't poke, at all.
At a stock power level and for street driving, if your tires are worn out and it's time to get new ones, get 285s. They'll give you a bit more of what you're looking for without costing significantly more.
