2019 C5 of the Year -- Performance Modifications
Received 1,305 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
For Corvetteforum’s 2019 C5 Corvette of the Year competition we have some big changes in store to make the competition more inclusive and, we hope, more fun for site users.
The changes include opening the contest to site users across the globe, rather than limiting it to residents of the contiguous United States. Further, we’ll break the competition down into four categories:
The reward in each of the categories is bragging rights and a designation under your user ID declaring your winning status.
This thread is for entries of Corvettes with Performance Modifications.
You can enter just one of the categories of competition and you do so by posting one photo of your C5 in the appropriate thread no later than 11:59 p.m. PDT, June 14. Moderators then will pick ten of their favorites as finalists and set up a poll to allow you to vote on which of those finalists is the C5 Corvette of the Year in each of the above-referenced categories. The judging, of course, is subjective and will be heavily influenced by the quality of the photographs submitted for the entries.
In subsequent months, we’ll feature other generations for Corvette of the Year with the winner in each of those generations competing for Corvetteforum Corvette of the Year.
The fine print: One entry per member. This contest is open to site users over the age of 18 who own the car they enter. Cars which have previously won are not eligible. Entry photos must have been shot by the Corvette's owner except in the track car category where the Corvette has been photographed on the track while the owner was driving it.
- Stock Corvettes
- Corvettes with Appearance Modifications
- Corvettes with Performance Modifications
- Corvettes prepared primarily for track use
Last edited by Vetteman Jack; 06-08-2019 at 08:17 AM. Reason: Corrected deadline date.
Popular Reply
06-07-2019, 01:01 PM
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Not a lot to see here externally but it's what's under the hood:
Performance Modification:
TSP Forged LS3 377 CID Shortblock (stock crank, Eagle Rods, custom Diamond pistons)
Tony Mamo 235 NFI Heads w/10mm rocker upgrade (9.7:1 SCR, 68CC chamber, hollow valves, AFR 8019 Springs)
LSA Head Gaskets
Yella Terra 10mm Rockers
Manton 11/32 .120 custom length pushrods
Johnson 2116LSR limited travel tie bar lifters
Mamo spec camshaft
Mamo ported LS2 Throttle Body and Intake Manifold
Mamo Spec ATI Balancer
ARP Balancer Bolt
ARP Camshaft Bolts
ARP Header Bolts
ARP Head Studs
Mamo Ported Melling Oil Pump
Original PFadt Motor Mounts
Llingenfelter LNC-001 2-Step Launch Control (I believe this was the first one sold publicly and I helped LPE write the instructions on this)
160° Thermostat
97-98 LS1 Return Fuel Rail
Bosch 95lb Injectors w/Michigan Motorsports upper hats
Lonnies Double Pumper in-tank whalbro setup
Alky Control Methanol Injection system
APS Twin Turbo System with modified inlets, filters, and LG 70 lb/min turbo upgrade
Turbosmart Dual Port BOV's
Turbosmart eBoost2 controller
Turbowerx EXA Scavenge Pump
Custom drain sumps on turbo's
Custom -10 drain plumbing to turbo's, -6 from turbo to welded fitting in timing cover for return
LG Big 3 rear exhaust
Ram Twin Disc Clutch
2008 ZO6 TR6060 transmission
2008 ZO6 Rear Differential and Cradle
Hurst Shifter
Bilstein Sport Shocks
C6 ZO6 brake calipers (powder coated translucent copper by Mike the Powder Coater)
Racing Brake 2 piece front and rear C6Z rotors
Fastbird (e.g. my own) Line Lock
CCW SP500 Wheels, 18x9.5 and 19x11, big brake offset, Bright Brushed Anodized finish
Michelin Pilot Sport PS2 front tires 275/35-18
Nitto NT05R Drag Radial Rear Tires, 305/35-19
And a few non-performance items:
Autometer Nexus Gauges in triple pod (Fuel Pressure, Boost/Vac, Wide Band)
Corvette Enhancements Blackouts
4EyesC5 low rise projector kit (currently uninstalled)
PAC Ipod Controller (CD Changer removed)
F45 Delete due to turbo kit, controllers removed
Probably forgetting a few things.
Motor is back together, car is nearly back together after the top end refresh. On the previous setup, car made 825-850+ depending on boost with the same shortblock, and a LPE GT2-3 cam and Patriot Stage 2 317 heads. Car went 202 at the Texas Mile in 2012.
LSA Head Gaskets
Mamo spec camshaft
ARP Balancer Bolt
ARP Camshaft Bolts
ARP Header Bolts
ARP Head Studs
160° Thermostat
Hurst Shifter
Pro Mechanic
LSA Head Gaskets
Mamo spec camshaft
ARP Balancer Bolt
ARP Camshaft Bolts
ARP Header Bolts
ARP Head Studs
160° Thermostat
Hurst Shifter
LSA Head Gaskets
Mamo spec camshaft
ARP Balancer Bolt
ARP Camshaft Bolts
ARP Header Bolts
ARP Head Studs
160° Thermostat
Hurst Shifter
The following 6 users liked this post by Fastbird:
2quick98 (06-11-2019),
BlackHellcat (06-10-2019),
C5R USA (06-09-2019),
FYRARMS (06-10-2019),
Mr. Black (06-08-2019),
and 1 others liked this post.
BBS LeMans wheels, ACS rear spoiler, Flush mount European taillights, SS fuel door,
Bassani long tube headers w/ crossover pipe & Hi-flow cats. Mallett Carbon Fiber mufflers,
Lunati cam, Hurst Shifter, RM racing twin-flow intake w/dual K&N filters. Drilled & slotted rotors w/ceramic pads. Tuned at Dragonsbreath Performance.
rjwvetttt (06-11-2019)
Received 1,261 Likes
The following 7 users liked this post by neutron82:
kzoo-z (06-13-2019),
lewislgZ06 (06-09-2019),
and 2 others liked this post.
Here is my Mag Red 623 WHP '99
Performance:
Vortech supercharger w/Intercooler
PRC heads
Kooks headers & x-pipe
Exhaust cut-outs
C5Z Titanium axle-back
Meth Injection
Homemade plate filler intake
Nitto NT01 tires
Corbeau A4 Seats
SacCity manual fan switch
Trans Brace
Upgraded Clutch
MGW Shifter
Auto Meter Boost & Fuel gauges on A Pillar
MSD Plug Wires
DeWitts Radiator
Silicon hoses
Powerdex A/F Gauge
Appearance:
C7 Carbon Race Spoiler
OEM C6 Gumby wheels painted Dupli-Color Graphite w/1" rear spacers
Z06 Fog Grilles
RPi acrylic light covers all around
LED Tails
LED front turn signals, License plate & reverse lights
LED fogs & headlights
Torch Red leather door handle pulls
Torch Red/Black leather shift boot & e-brake boot
Torch Red/Black leather arm rest cover
Hydrocarbon Shift bezel
Black rear "Corvette" fill-ins
Torch Red dash "Corvette" fill-ins
Carbon fiber A Pillar overlays
Tinted windows
MGW Shift ****
Calipers painted black
Valve covers painted Mag Red
C5 logo floor mats w/"C5" dyed red
Torch Red Steering wheel emblem overlay
Carbon fiber front & rear emblem overlays
Carbon fiber Corvette flag overlays on wheel center caps
RPi splash guards
Stereo:
Pioneer Double Din Head Unit
Rockford Fosgate Subwoofer
Infinity components in doors
Infinity rear speakers
Arc Audio Amp
Performance:
PRC heads
Exhaust cut-outs
Meth Injection
Nitto NT01 tires
Corbeau A4 Seats
Trans Brace
Upgraded Clutch
MGW Shifter
MSD Plug Wires
DeWitts Radiator
Silicon hoses
Powerdex A/F Gauge
Appearance:
Z06 Fog Grilles
LED Tails
Tinted windows
MGW Shift ****
RPi splash guards
Stereo:
Arc Audio Amp
01 C5
Aldan American coilovers
Hotchkis sways
TSW wheels
Wilwood Brakes
Vararam intake
TSP headers with corsa knock off axle back
Corbeau LG1 seats
C7 carbon skirt and splitter
Anderson composites hood
Dewitts rad/fans
4eyec5 headlights
tons of other little stuff.
The following 3 users liked this post by 2k2wranglerx:
LSA Head Gaskets
Mamo spec camshaft
ARP Balancer Bolt
ARP Camshaft Bolts
ARP Header Bolts
ARP Head Studs
160° Thermostat
Hurst Shifter
LSA Head Gaskets
Mamo spec camshaft
ARP Balancer Bolt
ARP Camshaft Bolts
ARP Header Bolts
ARP Head Studs
160° Thermostat
Hurst Shifter
