RPO codes from VIN
Old Jul 6, 2019 | 09:29 PM
bbrown450's Avatar
bbrown450
Default RPO codes from VIN
I have buddy looking at a 97/98 C5 with very low mileage ...bit of a barn find but I wanted to know if there is a site to check build codes w/ options via VIN #.
Thanks in advance !!
Old Jul 7, 2019 | 07:09 AM
89nascar's Avatar
89nascar
my 98 has the RPO codes on a sticker under the drives side rear well cover
Old Jul 7, 2019 | 09:50 AM
Carmine97's Avatar
Carmine97
Cruise-In I Veteran
The RPO code sticker that 89nascar mentioned is the easiest way.
Otherwise, the build sheet may be rolled up inside the front bumper beam of the chassis or you can order a build sheet and/or a window sticker from the National Corvette Museum.\:
https://www.corvettemuseum.org/learn...ndow-stickers/
If you find the RPO code sticker, take a picture, post it, PM me and I'll decode it for you...
Bob
Old Jul 7, 2019 | 10:49 AM
bbrown450's Avatar
bbrown450
Ok I have read where all C5’s build sheets are in the front fascia ... I will check once he buys ...thanks
Old Jul 7, 2019 | 10:50 AM
bbrown450's Avatar
bbrown450
Great thanks !!
To RPO codes from VIN
