how to fix a deep scratch ?
Guys,
I had a run in with . shovel in my garage, leaving a short but kind of deep scratch in the left rear quarter. Any advice on a product I can use as a body filler prior to touch up?
Thanks in advance,
Tim
Thanks in advance,
Tim
Free bump!
Following, as I have almost the same damage on the opposite fender in almost the same location. I got mine free of charge in a best buy parking lot.
ArmchairArchitect (07-09-2019)
I had one similar and I carefully filled it with layers of touch up paint. Mine was lower on front fender and is totally un noticeable now. Yours is in a worse spot. Might want to take it to a pro and get his recommendation.
Looks like it is down the SMC. Shop manual recommends treating SMC just like fiberglass. I would start with some filler to get things level, then touch up paint. You will probably have to wet and dry "sand" the area to get everything even. Don't forget the clear coat to finish. The auto parts chains sell small tubes of body filler - no need for a big can of Bondo.
Oldtimer
I had a similar problem with a welcome to the cruise nite canopy. Wind came and picked it up. Leg hit my fender. I tried to do what many have and there’s lots of videos for but metallic paint is another ballgame.
Here’s a progression of my (lack of) progress:
1/4 mile/AutoX
my biggest fear owning a silver car !!!!!!!!!!!
The OP's scratch looks like the type that would mean I need a new car. The scratch in the post right above, looks like a simple wet sand and buff would have made it 95% better and was made worse by the attempt to conceal.
Not4spd (07-09-2019)
1/4 mile/AutoX
wished I could find my pic's. same yellow Vette color, had a chip in the drivers fender, drove me nuts. used https://www.automotivetouchup.com/?A...otouchup.com_e filled and sanded the chip and blended the paint over the area (made the mistake of tapping it off) sanded with 600 grit to 1500, then rubbed it out. completely gone !!!!! will try to find pic's
1/4 mile/AutoX
found them !!!
chasboy (07-08-2019)
RXTbone (07-09-2019)
Ammo NYC has a video about this, too--
https://www.youtube.com/watch?v=Uz-zW-cLdUs&t=705s
So after the touch up there's no buffing to smooth it all out??
I've not used Dr Colorchip myself, but this is a good video of how it's used on a non metallic color. Hope this helps!
https://www.youtube.com/watch?v=ogpm_u7CfMY
I watched this a couple times, and it looked to me that I could still see the chips. But he did say if you're OCD you can do multiple applications. And since I am, I'd have to keep doing it til I couldn't see the chips at all!
Edmund Iverson (07-09-2019)
Oldtimer
I watched that video and ordered that fineline paint pen, since I have other chips....
