700 WHP 1/2 mile advice
FYRARMS (07-17-2019)
1/4 mile/AutoX
about 2500 rpm and let the clutch out slow don't pop it, then once out start accelerating !!!!
Received 1,261 Likes
do you spin at the top of first?... if not, roll out easy and then nail it... if you do spin, roll out easy and get on it and then short shift to second and nail it... just depends what kind of traction you have
also what pressure do you have in the tires?
I run my 305/35/19 et street ss at 22psi, you can start at 25 and go down if needed... I wouldn't go too low to avoid losing stability since you will be running the car to 170 or so
