Replacement Vacuum Actuators HVAC
Old May 20, 2020 | 07:37 PM
Joshclifford84's Avatar
Joshclifford84
Default Replacement Vacuum Actuators HVAC
Do we have a source? Looks like they are discontinued.
Old May 20, 2020 | 11:21 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
try Ebay....sometimes people sell that part separately from the big unit
Old May 23, 2020 | 07:34 PM
Mickeyrx70's Avatar
Mickeyrx70
They’re available on Amazon (Dorman 604-106) for $75.
Old May 24, 2020 | 06:03 AM
Joshclifford84
Lookin for the vacuum actuators
Old May 24, 2020 | 08:49 AM
Mickeyrx70's Avatar
Mickeyrx70
My bad.
Old May 24, 2020 | 06:05 PM
Joshclifford84
No problem at all, thanks for chiming in. Turns out somebody drilled a hole in this!?? I can't see any way this happened on accident. There is nothing near it you would drill into. Mind boggling. I bought the car this way last year. The car had 23k miles and it's mint. But I noticed the vents would never fully blow fwd and after testing found a vacuum leak in the blue hose. Which led to me digging this out. I have since sealed it up and works fine now but wtf. Every screw looked un touched accept the lower dash were someone installed a colum lock bypass. But that was a plug in module no soldering or anything needed. It was either a small drill bit or a fine tip solder iron poked it. But again there is no evidence of electrical work under there... Wow.
Old May 24, 2020 | 06:57 PM
Mickeyrx70's Avatar
Mickeyrx70
That IS mysterious. Glad you were able to seal it up.
To Replacement Vacuum Actuators HVAC
