[Z06] Switching fronts to back..........
Old Nov 29, 2002 | 03:44 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Default Switching fronts to back..........
Has anyone ever, when going drag racing, put your fronts on the rear and visa versa............... :crazy:
Old Dec 1, 2002 | 04:17 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Switching fronts to back.......... (VNAMVET)
Why?? :confused: :confused:
Old Dec 1, 2002 | 05:44 PM
pridnjoy's Avatar
pridnjoy
Cruise-In III Veteran
Default Re: Switching fronts to back.......... (binksZ06)
uhhh no. :crazy: :crazy: :crazy:
:nono: Don't do that! :nono:
Old Dec 1, 2002 | 06:38 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
we're obviously missing something, why would anyone want to do this? :confused:
Old Dec 2, 2002 | 07:41 AM
VNAMVET's Avatar
VNAMVET
Default Re: Switching fronts to back.......... (NEPTUNEBILL)
I thought a smaller tire (diameter & circumference wise) would let the engine be at a higher RPM. As it is now, I shift into 4th just before the end of the 1/4 mile. I was thinking (OBVIOUSLY flawed!) that by changing rim and tire sizes,
I would get into 4th a bit earlier, and into a bit more of the useable powerband, rather than just getting into the "beginning" it.
I know that if I went to 3.73's I would be doing MUCH more. Mabe I should just order one up and make a trip to Norris Motorsports? :confused:
Old Dec 2, 2002 | 06:52 PM
Scott-2002-Z06's Avatar
Scott-2002-Z06
Just amagin trying to hook up with a smalle tire! :eek:
:cheers:
This is what i think. Just think of how far one revolution gets you with the rear tire, the distance travled would be longer/further than with the front tire so you would have to switch gears sooner but your distance travled will be much shorter, at least that's what i think! :cheers:
[Modified by Scott-2002-Z06, 11:56 PM 12/2/2002]
To Switching fronts to back..........
