high oil consumption?
I bought a 2003 Z06, 105K miles, about two months ago and have noticed high oil consumption.....worse than my old Subaru. I use it as a daily driver, about 600 miles/week, gas up at least twice a week due to gas gauge issue, had a fresh oil change a month ago and still putting in a quart of oil every two weeks. This morning I had to put in two quarts. I do not see blue smoke on start up or while driving, not drips/leaks on my driveway, so I'm wondering if this is something normal-ish? This being my first Corvette, and I know most are not putting on this type of mileage on theirs, but is this just something to get used to? I do some spirited driving on the back roads and highway every now and then but it usually never gets above 4000 RPMs on a normal basis. Thanks.
Robb
Robb
As for your car's oil consumption; you are likely going to get a lot of opinions here, many folks will tell you their cars don't burn a drop between oil changes and you are not likely going to hear from anyone who is adding a couple of quarts between oil changes. That's human nature. The LS 1/6 engines can (not all of them do) use quite a bit of oil, particularly when you get into the higher rpms. There were a number of bulletins on oil consumption, here's a quote from one I lifted off of another forum:
"Condition
Some owners may comment on higher than expected oil consumption. When checked, the oil consumption could be in the range of 400-600 miles per quart (700-1000 km/L).
On the LS6 engine only, the technician may find oil behind the engine throttle plate and in the intake manifold.
Cause
The cause for this condition may be an interaction between the piston rings and the cylinder bore in vehicles that are operated at higher RPMs -- typically manual transmission vehicles driven in a manner where the engine is frequently or consistently operating at greater than 3200 RPM."
https://ls1tech.com/forums/generatio...nsumption.html
I happen to own a high miles (approaching 115,000) '01 manual and the '01 year is so notorious for high oil consumption that some folks would pass on that year. I have noticed higher oil consumption the harder I drive the car. Like that bulletin says, I think the manual transmission cars are going to be more prone to higher oil usage because we tend to send our tach into the higher range...because we can. I tend to need a quart of oil after 3,000 miles and I'd estimate my car uses as little as 2 and as many as 3 quarts of oil between oil changes as indicated on the DIC. So compared to my car, yes, your car is using more oil. On the other hand, your car is using half as much oil as some owners of new Z06s were reporting in 2003. Check a few things if you like, but I would not lose any sleep over it, just keep a couple of quarts of oil in the trunk.
"Condition
Cause
As per the oil consumption. I've heard of oil consumption when it comes to tracking the C5. The high rpms seems to cause the oil consumption.
I can honestly say I can't ever remember adding oil to any of my C5s between oil changes, and I've owned five C5s.
tune up is next on the list... already had to do window regulator, water pump and radiator unexpectedly.
As for your car's oil consumption; you are likely going to get a lot of opinions here, many folks will tell you their cars don't burn a drop between oil changes and you are not likely going to hear from anyone who is adding a couple of quarts between oil changes. That's human nature. When checked, the oil consumption could be in the range of 400-600 miles per quart (700-1000 km/L).
I know it sounds like black magic- I was never a believer in fuel additives. But a lot of folks have had success with this, so trust me when I say the evidence of it working is not purely anecdotal.
As for the oil usage I think if you google LS1/6 oil consumption you will find this issue has been identified as far back as 20 years ago and you will not feel so troubled by your car. I drive my car...not quite as much as you are currently driving yours, but I've clocked 18,000 miles over the last 3 years and I think that if folks drove their cars as the car was meant to be driven (enthusiastically) they might see some oil consumption- some more than others depending on the engine and driving style. The surest way not to use any oil (or gasoline for that matter) is to park it.
Robb
Check your PCV system as someone other mentioned
unfortunately it kinda comes with the territory on these LS engines.
