Crate LS364 swap?
I took the car to a performance shop in town and got a quote to pull the tired old LS1 out and do some heads, cam, intake, tune, and throw an LS7 clutch on it. They guy quoted me $30,000.00. Obviously he doesn't want to do the job.
Another guy who is independent and works out of a one man garage offered to do the work, wanting about $4G to pull and reinstall. That being the case, I wondered if it was a better deal to get an entire new engine with a warranty rather than working with the 86K mile 22 year old bottom. So I see GM has a deal on this crate specifically designed for retrofits.. has the 24x crank and 1x cam sensors already installed, and LS3 heads.
https://www.gmperformancemotor.com/parts/19370163.html
The price is right, if my guy is accurate with his labor I could have this engine and an LS7 clutch installed for under $10K. If this were your car, would you do this? Iron LQ9 block and all? I never intend to track this car, I only street cruise it on weekends, rub it with a diaper, etc. LOL. But is this enough torque to keep any rice burner from surprising me between the lights? The trusted guy suggested dropping the rear end to 3.73s to really make it hop out of the hole. I need some solid advice here... Anyone running this set up? Or what do you think otherwise?
D
Be careful. Fools and their money, as they say, and we have the Corvette tax on top.
I highly recommend you make no purchases for 60 days. Read, watch, ponder during that time. First, what is your goal for the car? A hp # to brag? A trap time and speed of X.XX @ 1XX? From there you can back into what you want to do for build on the car.
Now I fully agree with above. 86k is nada on these engines. You can slap a blower on it as a stand alone mod and it will do fine. There are some smart add on mods to improve on some factory weaknesses like pac springs, Che or Straub bushings, a good (not just LS2) new timing chain, maybe a new oil pump. A cam is optional. When the clutch goes, LS7 is fine... It is... It for the labor cost if you're not doing the work, I'd suggest an RST for lighter than factory pedal with 800tw grip. Do the couplers while you're in there. Definitely add the Katech remote bleeder. And when you do the blower, the one main key is find a tuner who has done hundreds of these combos so you have some faith they won't nuke your engine with a stupid mistake.
There ya go. The path to 550 to 650 rwhp is before you with easy driving and maintenance.
Oh.and do an HPI diff mount and ECS trans/diff brace when all this is done.
Have fun and smile every day! All for probably WELL under 10k. Well, belay that be I have no idea what sort of labor you'd be looking at. Hook up with your local Corvette club members and ask them to refer you to someone. DON'T ASK THE RETIREES WITH CLEAN HANDS AND POLO SHIRTS. Ask the dudes who hit the track weekly. They'll know the right guys for the right price.
just my humble opinion, but which ever way you go, good luck, and enjoy!
D
No idea if they would put in a new clutch or not, but you could ask, if so they could do clutch and check torque tube couplers etc.
Could make it a 2 for 1, get car upgraded and vacation, might have to rent a car or call Uber while Corvette is being worked on.
By the way my 1999 6 speed convertible is still stock and runs great, they say these engines can go 200-300 k or more.
Call A and A and see what they say.
Edit, you say your LS1 is tired? Is not running good?
I am also a very happy customer running a McCloud clutch. (RST) Modulates perfectly, and has a smaller rotating mass than stock. Use caution when selecting an aftermarket clutch, most are sold to satisfy a racer, and the on/off light switch response is not a good choice in traffic where you might have to leave at the pace of the traffic around you. McCloud, back when he was first starting out, started painting his clutches red so guys in the pits could identify which clutches were still working, as some drag guys like to keep successful parts selection a secret for as long as possible. Now it is common for a clutch to be factory painted, some are green, but red is still the most common color, regardless of brand.
