Brake Fluid
Old Nov 16, 2021 | 08:32 PM
NicHC's Avatar
NicHC
Default Brake Fluid
Recently realized I am very much in need of a brake and clutch fluid change but I'm not sure what I should go with. I have a 2001 pro-charged Z06 and I don't track the car but I would like to have a high boiling point brake fluid for when I'm feeling a little risky on public roads, any ideas on what I should go with?
Old Nov 16, 2021 | 08:35 PM
heggsc5's Avatar
heggsc5
If you're at the point of boiling regular old parts store Valvoline synthetic DOT 3/4 on public roads, you should probably have your license taken away. Works just fine for my clutch and brakes
Old Nov 16, 2021 | 08:48 PM
NicHC's Avatar
NicHC
That's a fair point, maybe going from 0 to 100 then back to 0 again between every stoplight isn't a good idea... lol.
Old Nov 16, 2021 | 11:24 PM
jim993's Avatar
jim993
ATE Typ 200, what I've used on track for many years.
Amazon Amazon
Old Nov 17, 2021 | 09:03 AM
Old School's Avatar
Old School
The higher boiling point Dot 4 fluid is compatible with Dot 3 so you don't have to worry about mixing and it's only a couple bucks more. I've also used the ATE typ 200 that jim993 mentioned above, it's good stuff for cheap
Old Nov 17, 2021 | 10:19 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
https://www.amazon.com/ATE-706202-Or...003VXRPL0?th=1
Highly recommended. This is the best budget option. You can go to Castrol SRF for max performance, but it's 3x the cost. The ATE is a solid upgrade.
Old Nov 17, 2021 | 11:29 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
This is what I run in my A&A supercharged '04. I combined this with a Hawk HPS 5.0 pad, and it handles the heat very well.
Old Nov 18, 2021 | 05:34 PM
1wholikescars's Avatar
1wholikescars
ATE type 200, I also use it and have for years in my cars, nice stuff.
To Brake Fluid
