[Z06] Steering Intermediate Shaft Label
Old Apr 17, 2022 | 12:14 PM
RMBLROAR's Avatar
RMBLROAR
Default Steering Intermediate Shaft Label
I'm doing a little research on the intermediate steering shaft for a 2004 CE Z06. For those of you that have a CE is there a label warning about removal of the shaft glued to it? The label looks like the one in the attachment.....
Old Apr 17, 2022 | 02:18 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I have the same one on my 01z.
It’s simply warning not to turn the steering wheel if not hooked up to the steering gear via the shaft with the sticker.
The steering wheel has a small clock spring that will break if turned too many times (which isn’t possible if the shaft was hooked up).
Old Apr 18, 2022 | 10:56 AM
RMBLROAR's Avatar
RMBLROAR
Thanks for your response. Mine doesn't have that label and I don't see any residual sign that it was ever there. That's why I'm trying to find out if others with an '04 Z06 have the label. Mine probably fell off at some time but I would think all models would have had it attached....
To Steering Intermediate Shaft Label
