Adjust ABS/TC pressure
When I get on a new track, I like to keep TC on just to save my ***. However, my car is getting quite different than the OEM setup, and at high speed, I get the TC to kick in and try to apply some corrections. This isn't a big deal normally, however, I run DTC70 on AP Racing calipers and the car. This combinaison requires very little pressure on the pedal to bite fairly hard, which end up being way too aggressive on the correction.
So, I was hoping to adjust the pressure applied to the brake by the ABS pump.
Any of you guys know if that's possible?
