[Z06] Ignorant 'regular' C5 guy needs to know...
Old Mar 31, 2003 | 11:43 PM
Sparticus's Avatar
Sparticus
Default Ignorant 'regular' C5 guy needs to know...
How does the Z shave off a couple hundred pounds? Is it the roof?
Old Mar 31, 2003 | 11:47 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Ignorant 'regular' C5 guy needs to know... (Sparticus)
The hardtop is lighter than the hatch glass but its also things like no runflats, thinner windshield glass, Ti exhaust, and a few other minor things.
[Modified by C5Longhorn, 10:48 PM 3/31/2003]
Old Apr 1, 2003 | 12:16 AM
Gaijin's Avatar
Gaijin
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Even the battery is designed to be lightweight (different from C5 coupes/verts). Insulation and carpeting too. Manual passenger seat. Fixed mast antenna. CD changer not factory option. And the "creme dela creme," the LS6!
Old Apr 1, 2003 | 01:28 AM
User 81424's Avatar
User 81424
Default Re: Ignorant 'regular' C5 guy needs to know... (Gaijin)
Aluminum torque tube, and less air in the tires :lolg:
Old Apr 1, 2003 | 03:38 AM
WWK888's Avatar
WWK888
Default Re: Ignorant 'regular' C5 guy needs to know... (CPT Z06)
Skinnier owners... :D
Old Apr 1, 2003 | 08:18 AM
ragvette's Avatar
ragvette
Default Re: Ignorant 'regular' C5 guy needs to know... (WWK888)
:lolg: :lolg:
I wish.
Old Apr 1, 2003 | 05:36 PM
IH8PONYS's Avatar
IH8PONYS
pistons, rods also have been changed to make things lighter!
Old Apr 1, 2003 | 06:01 PM
E RACER's Avatar
E RACER
No covers for the rear compartment holes.
Old Apr 1, 2003 | 06:47 PM
SpdKilz's Avatar
SpdKilz
That is VERY true in my case...140 and proud of it :D
Course I still have a growth spurt coming my way (I pray!)
Carleton
Old Apr 1, 2003 | 11:49 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Ignorant 'regular' C5 guy needs to know... (E RACER)
No Spare! :yesnod: :cheers:
Old Apr 2, 2003 | 02:33 PM
wt2ga's Avatar
wt2ga
No FEAR :cool:
Old Apr 2, 2003 | 03:15 PM
SWCDuke's Avatar
SWCDuke
Default Re: Ignorant 'regular' C5 guy needs to know... (wt2ga)
F1 Supercar tires weigh less than runflats. Wheels may be lighter, too.
Duke
Old Apr 2, 2003 | 08:19 PM
Copmagnet's Avatar
Copmagnet
also, balsa wood in between the floor of the cab.
Old Apr 2, 2003 | 08:35 PM
SWCDuke's Avatar
SWCDuke
Default Re: Ignorant 'regular' C5 guy needs to know... (Copmagnet)
All C5s have the balsa wood core composite floor panels. C6s will get the same on the load compartment floor.
Duke
Old Apr 4, 2003 | 06:04 PM
Tracy's Avatar
Tracy
Default Re: Ignorant 'regular' C5 guy needs to know... (SWCDuke)
As mentioned above, the wheels are a bit lighter, like 3 lbs each. No power passenger seat on Z, either, probably 8-10 lbs or so.
As for the carpet, the front seems to be the same (yes?), but the junk that's in the trunk area can't quite be called "carpet". It's very thin.
It's all a bunch of little things, but they all add up. :cheers:
Old Apr 4, 2003 | 10:58 PM
Bertrand's Avatar
Bertrand
Default Re: Ignorant 'regular' C5 guy needs to know... (Tracy)
The titanium exhaust and thinner (and smaller for the rear glass/hatch) glass is a large part of the equation. All the other items mentioned contribute as well. :cheers:
To Ignorant 'regular' C5 guy needs to know...
