I believe red is the removable, and blue is permanent Loktite.
Or was the green bottle for beer better, or brown? Ah heck,
just make sure it's removable Loktite.
:cheers: :chevy :lolg:
Red is permanent. Do not use it if you ever want to remove the bolts again.
The manual probably recommends loctite on the caliper bolts but I have had mine off several times and have never used any loctite. Be sure they are properly torqued.
Dave
Dave
I could be wrong but my manual said to replace? :skep: :skep:
