Weather stripping Emulsion.
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
A month or two ago there was a post asking what to use on the weatherstripping. I posted a pic of the GM emulsion that I use. Instead of what a lot of people here use which is dielectric grease.
Someone said the emulsion had been discontinued. Well I was at the dealership today and bought some more. New label and part number. I just thought you would like to check it out. I think this stuff is great. It actually puffs up dried out weatherstripping. Without being greasey.
The old container is on the left. New one on the right.
Hey Stock Man, this is perfect timing. I was the one that asked you a couple of months ago about the silicone emulsion. I showed the photos and part number to my friend that works at a GM dealer, but they were never able to find it in the system and order it for me.
Well, I went to search for the thread you posted with pics, so I could try a different dealer, but it must not have been transferred from the old software. I did find this thread, and with new photos and part number as well!
Thank you, your help is appreciated.
Jody
Jody
Jody
Jody
I've tried several different GM dealers in my part of the country with out any luck. Seems as many of the GM dealers have quit stocking it for whatever reason since it went from a GM label product to the AC/Delco label. Most have suggested checking with the larger suppliers or distributors of the AC/Delco brand in my area which I haven't done yet. Good luck with your search.
You would think with the part number they would order it in!!! It's $5.00 up here which means it's about $3.50 down there. Not a major item to keep your customers happy. I wonder if Ken Fichtner could get some and sell it here on the forum?
Originally Posted by Shylor
What is this stuff designed for? I ask because the dielectric grease is what is recommended by GM.
About 10 years ago when I bought a Bonneville the dealer turned me onto the emulsion for the weatherstripping. I've been using it ever since and it works wonders on even older weatherstripping. Puffs up old weatherstripping like new. And I just thought I'd past it on if anyone here wanted to try it. But it sounds like everyone here is using the dielectric grease for their striping and seem to be happy with the results. But I just though some would like to try this as a change of pace. And it' pretty cheap and is a GM or AC/Delco product. So that's what's up with the emulsion. Hope that helps.
GrayC5,
Thanks for the info. It appears I may still have some difficulty finding the emulsion, but I'll give my usual channels a try. Then if I have to, an AC Delco supplier.
Stock man,
I agree, it seems like a simple thing for a dealer to stock, or at least find. Ken Fichtner or Fred Beans may be able to find it.
FWIW, I know the manual recommends the dielectric grease and a lot of people have good results with it, and that's fine. I just don't like using it, and wanted to try something different....easier to spread, and no greasy residue. It's all good.
Stock man,
I missed the original post. I use dielectric grease on my weather-stripping.
You need to be careful with some sprays, make sure the propellant is good (compatiable) with weatherseals. If it "puffing up the gaskets" I woud be concerned.
........ Instead of what a lot of people here use which is dielectric grease. ......
Seems to me GM is going to specify what is best for the seals. Why use something different? The dielectric grease works well, is widely available, and is inexpensive.
Received 19,284 Likes
'20-'21-'22-'23-'24
Thanks for sharing. I need to do something with my weatherstripping. I'll have to give the parts department a call.
I'm going to try this one more time. What is the emulsion stuff designed for?
Stock Man did not say this product stated it was used for conditioning and preserving weatherstripping. He said that he used it for that. I want to know what the intended purpose of this product is, not what people have used it for.
You got my attention!!!! Here's what the label on the back states.
ACDelco Silicone Emulsion has been developed to meet General Motors engineering specifications. Use it to keep weatherstripping soft and free from sticking. Paint on stripping and let dry.
That's it!!! And that's what I have been using for about 10 years now. I don't put it on very liberally. I spread it right out and found it works great. Hope this helps.
