CLB is not the answer
Old Jul 17, 2004 | 04:33 PM
corvettebob1's Avatar
corvettebob1
Default CLB is not the answer
My column locked in my 98 A4 and I read a lot of post's reguarding the CLB so I installed one.
So within a week the car started throwing all kinds of codes and not starting sometimes.
It about drove me nuts, one of the codes was a 2721 which means the passcode is incorrect.
So I tried to do a key re-learn, well with this POS installed it will not do it.
Last night I installed the factory recall parts to correct the problem, it consistes of a different lock plate and a harness that completes the connection through the lock rod drive motor and also a new ingition switch.
So guess what now? Well everything works just fine
So before you wast money on a CLB do it the right way!!!!!!!!!!!
Old Jul 17, 2004 | 04:40 PM
MrKegFlex's Avatar
MrKegFlex
Hmmmm.... I just installed a CLB on my '99 MN6 last night. I hope I didn't make the wrong decision.
Old Jul 17, 2004 | 04:46 PM
Patches's Avatar
Patches
97-98 are known to be finicky about the CLB. The vast majority of guys here running one have had no problems, me included.
I have read of several members getting repeated lockups even after two and three GM "fixes".
Best of luck with your's.
Old Jul 17, 2004 | 05:34 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by Patches
Best of luck with yours.
Old Jul 17, 2004 | 06:19 PM
Face's Avatar
Face
I get an occasional "pull key" message, that's it.
Old Jul 17, 2004 | 07:02 PM
LoneStarFRC's Avatar
LoneStarFRC
My "POS" is not giving me any codes or grief at all.
Old Jul 17, 2004 | 10:21 PM
red97vette's Avatar
red97vette
just recieved my CLB last night, havent installed it on my 97 yet,...but now im a little nervous...
Old Jul 17, 2004 | 10:34 PM
Monk's Avatar
Monk
[QUOTE=corvettebob1]My column locked in my 98 A4 and I read a lot of post's reguarding the CLB so I installed one. So within a week the car started throwing all kinds of codes and not starting sometimes. QUOTE]
I think that this should be taken as one more reminder that those of us with '97s and '98s should proceed with caution and not jump in a mad panic onto the CLB bandwagon without some serious thought.
Monk :flag :flag :flag
Old Jul 17, 2004 | 11:24 PM
CoRpSeMA's Avatar
CoRpSeMA
After about 2 weeks of having the CLB in my car ('97) I'm now getting engine mis-fires... plugs are good, wires are good.... should I try taking the CLB out? I'm not sure if thats the cause... I wasn't thinking it was, but should I try to remove it? Any ideas what these 'other guys' were having as problems?
Old Jul 18, 2004 | 12:06 AM
99 White FRC's Avatar
99 White FRC
The following is a post of a GM Mechanic from another site, I for one will take my chances and NOT install the CLB.
From a professional service standpoint, NO, it is not a recommended course of action. This is due to the fact that the column lock bypass does NOT correctly produce an electrical load on certain parts of the BCM during functioning. This, in turn, can create intermittant codes and problems with the BCM down the line.
Normally, if a customer insists on having the column lock disabled on the 6 speed, then it is suggested to install the GM kit for the automatics. This will correctly load the internal relays and create a reliable repair.
From a Chevrolet point of view, the recall 01044a solved the problem with those cars involved. And the 04006 recall that is being implemented will repair the rest of the conditions.
AS LONG AS THE REPAIR IS PERFORMED PER RECALL GUIDELINES
Unfortunately, sometimes other things happen, and there are people who blame the design. While it does leave some things to be desired, this is why the revised 01044a and the new 04006 recalls have been implemented. Nothing is perfect, but for the greater percentage of c5 that are repaired, they do not have a repeat condition.
Old Jul 18, 2004 | 12:42 AM
99 The Hard Way's Avatar
99 The Hard Way
I have installed the CLB in all 3 of the C5's I had- 98 coupe, 99 FRC, 01 Z06. All 6 speeds and never any problems. Guess I just got lucky. Scott
Old Jul 18, 2004 | 12:52 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Last year I had my '98 A4 column lock fixed (eliminated) as per GM recall 1044a. I have had no problems with faulty codes, etc. And ofcourse, it is now impossible for the steering column to lock up on me. If you have a '97, '98, '99 or '00 A4 Corvette, do not hesitate to get the GM recall "fix".
Old Jul 18, 2004 | 04:19 AM
lowdowndirty's Avatar
lowdowndirty
Sure, the GM fix is desirable. However, when GM has a recall campaign open for only a certain time, some people with potential problems are left out. When my column in my used 99 FRC took a dump, I went to two different dealers. Both said that the recall work had already be done and the campaign had been closed. When I asked what they could do, they both said that I'd have to foot the bill. Needless to say, I ordered the CLB and haven't had an issue yet with MY POS.
Old Jul 18, 2004 | 05:28 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Sorry to hear of your troubles...mine has been on the car for 4 years...NEVER a problem
Old Jul 18, 2004 | 06:27 AM
Monk's Avatar
Monk
Does anyone see a trend developing here? Seems that '97s and most 98's have trouble dealing with the CLB. Seems like some (late production maybe?) 98's and most 99 and up model years generally don't have these issues with the CLB.
Can folks with '98s and problem-free CLBs let us know their production date and/or VIN so that we can try to detemine a compatibility break point?
Old Jul 18, 2004 | 08:42 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I had a CLB on the 98 coupe I used to have for about 2 years with NO problems at all. I have a 99 roadster now that has the CLB for about 3 years now with NO problems. Go figure.
Tom
Old Jul 18, 2004 | 08:47 AM
Monk's Avatar
Monk
Originally Posted by TCW
I had a CLB on the 98 coupe I used to have for about 2 years with NO problems at all. I have a 99 roadster now that has the CLB for about 3 years now with NO problems. Go figure. Tom
Well, there goes my theory right out the door!
To CLB is not the answer
Old Jul 18, 2004 | 08:59 AM
LivinTheDream's Avatar
LivinTheDream
FWIW, My build date is June 4, 1998. I got my CLB from Zip after searching to see which vendor seemed to work for the older C5's. Believe me, my fingers were crossed knowing it may or may not work. After 60 days, no problems. If GM ever finds me, I'll let them do the new recall on my A4, as the previous owner never had the fix performed under the earlier recall, and it's locked out.
Old Jul 18, 2004 | 10:05 AM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Two Years No Problems ,
Old Jul 18, 2004 | 10:26 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
That quote has been tossed around for years now, and from an electrical standpoint, it's pure
Why have we not heard of anyone with a bad BCM due to the installation of a CLB? In his complete quote (you didn't get all of it), he claims he's fixing bad BCM's all the time on CLB-equipped cars, yet in my 2 years on this forum, can't recall ever reading about a single case of this happening...why is that?
He also claimed he's not seen many instances of repeat column lock failures after the GM fixes were done...yet those stories are not uncommon here.
I take his advice with a grain of salt. He is knowledgeable, but he's obviously representing GM, and has to act accordingly.
If the CLB did indeed cause the problems he's supposedly fixing "all the time", we'd certainly know about it by now.
