Help! Water is getting into my blower fan!??
Has anyone had this problem before? I pulled the fan out but couldn't find anything wrong. I then stuck some coat hanger wire up in the drain tube but there doesn't seem to be any blockage as I had the car idle with the a.c. on max and it would drain out. When I drive the car and make a right hand turn I can hear water getting in the fan. Any ideas?
not sure about this car's set up, but i have heard of heater cores leaking into the case doing the same thing in some other vehicles...have u checked ot make sure u dont have a water leak from outside leaking water inside somehow? good luck, and let us know in case we have same problem..
Well it hasn't rained in awhile and when I felt the water around the fan and smelled it,it didn't smell like antifreeze so I think it's comming from around the coil.
1 Post
My car use to be parked out side by the previous owner. There are as I remember a couple of drains on both sides of the car behind the front wheels. They are shaped like cow udders and held a ton of junk.
Good luck, Tom.
Good luck, Tom.
1 Post
I remember reading that some guy dismantaled the section just in front of the firewall and found all kinds of stuff, like carpet fibre, clogging up the works. So, maybe it will take more than the coat hanger.
Anyway, before water gets into the computer below the passenger's floor board, pop the computer out, put it in a plastic bag, and pop it back into place. This may help prevent an expensive computer replacement.
ArmchairArchitect (09-11-2017)
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Good luck, Tom.
Good luck, Tom.
I was able to use a long plastic tie to get up into the drain hose and when I did water gushed out! Apparently there was some dust+water=mud blocking the drain. Oh well alls well that ends well!
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good news!! I'll have to try that myself just incase things build up in there. Thanks for the post. Not enough guys tell the outcome of their problems. Great post!!
St. Jude Donor 06
I have the same on going problem.
I took the blower out and ran a vacuum hose in the hole about a year ago. I got a lot of leaves out.
I clean all the drains 3 times a year and still I have water getting into the AC blower and killing it.
I have filter mesh material over the cowl induction under the hood and I'm still getting leaves in the system.
(Oh yes the drain hose on the blower goes up from the blower. Great engineering GM)
Any other ideas as to how to fix these problems?
There is a small drain on the firewall.
Mine was clogged. Took a piece of coat hanger & was able to get it opened.
I had to get the car in the air to have access to it.
Impossible to reach from the top... Having small hands would help to.
Water gushed out of mine once I inserted the wire. No problems since.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are a few things here that are not being identified properly.
The windshield cowl well (TROUGH) area does a couple of things. It collects rain/water run off and directs the water to the left and right fender well areas away from the body.
YES, The trough UDDERS can and do become clogged. If all FOUR become clogged, that trough will fill full of water and that water WILL enter the AIR BOX! It will also flood out the windshield motor controller and cause it to do all sorts of weird stuff!
The HVAC OUTSIDE AIR enters the air box from under the small metal plate on the passengers side of the cowl well
The small opening under that metal plate near the passengers side of the cowl is where the HVAC System gets its air. Its also where the MICE get in!
Here is the HVAC Air Box fresh air opening:
There is ONE large drain tube on the passengers side and THREE on the drivers side:
PASSENGERS SIDE HOSE (disconnected from cowl):
This is the part that sticks shut and where the crap collects to clog up the hose:
The small RUBBER HOSE on the HVAC Motor is there to help keep the motor cool. It takes a bit of the cool air from the air box and pushes it through the motor. I've actually had that hose condensate and drip water onto the BCM on my 98. I wrapped some bubble wrap around it to keep it from forming condensation.
If you can hear water SLOSHING around the air box and into the fan housing, the HVAC Air Box is NOT draining. When the AC evaporator cools it develops condensation. Condensation water sometimes develops a SNOT LIKE SLIME and that crap can plug up the air box drain. You can use compressed air and blow it back into the air box and remove the fan and retrieve it and any other debris by hand. The small rubber 90 degree boot that fits onto the fire wall drain can also get clogged up and or stick shut. IF, you remove that tube or cut the end completely off of the tube, you will allow a significant volume of nice cool interior cabin air out to cool the engine compartment:
Bill
Bill
The following 3 users liked this post by Bill Curlee:
