z06 manifolds
Old Aug 28, 2004 | 05:36 PM
pissedoffdaddy's Avatar
pissedoffdaddy
5th Gear
Default z06 manifolds
Can you put z06 manifolds on a 99 coupe if you have the cats and h-pipe?
I think it should just bolt on am I correct??
Old Aug 28, 2004 | 05:39 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yes, but you will need to modify/adapt the passenger side AIR tube connection and possibly the dipstick mounting, as both changed in 2001.
Old Aug 28, 2004 | 05:56 PM
Slash's Avatar
Slash
I'd skip it.
The work is gonna be the most difficult part so you might as well install a set of headers.
While the z06 manifolds may increase hp I doubt you could tell the increase.
Look for a set of used headers and only do the work once.
Old Aug 28, 2004 | 06:34 PM
with Slash. If you are going to this much trouble, go ahead and install a set of LT headers.
Old Aug 28, 2004 | 06:41 PM
LoneStarFRC's Avatar
LoneStarFRC
Muuuch better. JMHO
Robert
To z06 manifolds
