Harbor Freight Jack
So I jack the car up from the sides. Thats where my 2cnd problem comes into play. The car is lowered 1". OK, no problem for this jack with 18" street wheels. But there is a prob once I get my RoadRace wheels on where I have 315's in the rear and 17" wheels all around.
It seems that when I want to remove the track wheels back to the streets, sometimes there is a little resistance in getting the jack under one of the rocker panels with the 17" wheels on. I presume its because the car with the 17" wheels is a tad bit lower, even though the 17" tire should negate it. So its back to the boards to get clearance.
What I would really like is a jack I saw that has a 3" height and is 30" long! That will pose no problems in getting to the beam in the front and will definitely pose no problems if I need to jack from the sides with my Track wheels on.
I'll have to find the link but the problem with this jack is its like 85 lbs!
Its also expensive but like so many others, I've learned to give up on splitting hairs on good equipment that does the job 100% of the time and does it the safest and proper way.
my car is also lowered.... the long nosed jack that reaches fromthe front cost close to 300 dollars... its a nice jack but very heavy... I just use my jack to jack up one side then I take my three ton jack and jack up the other side,.. For 130 dollars you cant beat this jack for a lowered C5. funny thing about the previous poster... he can get a 3 1/2 in jack under his 17 in wheels .. I wonder how any of these guys with a non run flat will get a jack under their car when the 2 in sidewall is flat and the car is stilling on the rim and the clearance to get a jack under it is 2 inches...
last evening while listening to the Ohio State Patrol on my scanner I heard one of the troopers call in that he had a flat but no spare. They had to tow him in . . poor planning . . at least he had a radio and a free tow
